Hossom :
Knives must be judged by their extended performance and from the kind of reasonable abuse that is incidental to real world uses.
This is the kind of ideal statement that sounds perfect, but in reality has really severe problems. For example, there are those with enough skill and care that heavy blade on inclusion contact happens very rarely. Thus if they followed the advice that Hossom noted they could not comment on that knife aspect for several years - that is pretty slow progress. Not to mention the fact that if you never evaluate a blades ability to handle an extreme event until it is forced upon it, it is pretty irresponsible. It would be like checking to see if a life jacket works by waiting until someone falls overboard and see if they drown. You intentionally do unlikely usage as it prevents you from having to be forced to rely on a blade that failed in the event of such a happening, and it allows you to examine such behaviour in a timely manner. Care has to be taken of course to try to duplicate the incidents in some kind of similar manner which allows ready comparisons, that isn't trivial.
It is the same as "knives should only be used for their intended purpose". This sounds like common sense of course. However how do you define the intended purpose. From the makers perspective? Let alone the fact that you are letting someome who makes a product decide how it is to be evaluated, what about if two different makers make the exact same type of knife (same promoted class and general use), but have radically different viewpoints on what this actually means. How do you answer the question of comparing them? If you look at it from the point of view of one you will be unfair to the other as you are either ignoring strong points that they have, or commenting on weak points that they think should be ignored. I don't think there should be any restrictions at all on useage for the purpose of evaluation. If someone wants to take a knife and perform a task when it was made to do something very different than they will learn why that was the case and they have gained something. If they comment that the knife was "poor" because it didn't do that well, that is a different matter, and the maker has obvous grounds to complain.
Blademan13 :
The main focus of Cliff's testing seems to be directed towards blades with ultimate toughness levels and heavy choppers.
No, that just gets the most press for obvious reasons. It depends on who is reading it of course, some people only focus on the breaking to the extent that they don't see anything else. See the Valiant thread for example. That never got the attention the Recondo one did even though the Valiant blade was just as heavily damaged, and subjected to far heavier use. The manufacturer simply didn't react the way Ron did. We just discussed the results, what they meant, possible changes etc. . In regards to comments about toughness being the most critical aspect. This is from the viewpoint of the integral nature of knife design. Durability defines geometry, geometry defines cutting performance.
Don't take my thin bladed brush blade and run it against a Battle Mistress doing heavy chopping into hardwood or stabbing and point strength tests. To then turn around and post a poor review of the knife is truly unfair as it makes the blade smith look unqualified for no reason at all.
The interpretation is left up to the reader, the opposite of course would also be done showing where the thinner knife outperforms the BM. Can readers make incorrect conclusions, possibly. That is why the reviews are linked to threads on Bladeforums so people can discuss the possible interpretations.
Brian Jones :
The ONLY valuable testing is our OWN subjective testing, period.
We are talking about wedges here, it is easily possible for one individual to give another useful information on the performance of one type vs another, just as you could tell someone about various types of tinder for fire starting or types of boots for various conditions. Yes of course the bottom line always has to be your experience, but you can speed this up quite a bit from others.
Richard :
Even more questionable is the ability to claim to know the force used by feel and also the variations, as though one can by feel if they are using 102 ft lbs +/- 2.74.
It wasn't estimated by feel, it was measured (mass, time and distance) as noted in the reviews. The variations were also not as small as 2%, which would be quite difficult indeed to try to contain on such a dynamic movement. Quoting 102 +/- 2.74 also doesn't make any sense by the way, you would match precision in both numbers, and tracking 3 numbers in the variation is rather extreme. Usually only one is necessary unless you are concerned about roundoff error in which case two is usually enough, there are better ways to deal with roundoff than excessive digits though, see for example the work le Roy has done on iterative rounding in correlated systems.
-Cliff
