Coffee
Cool beans, they even put your name on the bag! Agreed with the fresh roasted which is why I might switch to mail order and vac and freeze.
Whats the roast and flavor like?
Yes, they put your name on the bag when they roast the beans for your order. I have tried 3 or 4 different beans from them and all have been good but 2 have been my favorite ever. I am currently enjoying the Ethiopian Kochere and unfortunately I forgot the other one that l love so much and I don't see it currently offered on their website I'm not one for freezing beans but I do vacuum them in a mason jar and then store in a cool dry place and I also try not to order too much at once. I believe that the roast varies based on the bean. If you are looking to order some beans I would give them a shot.
49th Parallel, Vancouver B.C.
Guatemala Retana Single Origin Espresso.
Altitude: 1500 meters above sea level.
Variety: Bourbon
"Aromas of stone fruits and a round flavor profile, with balanced and integrated texture, and plum, apricot sweetness."
ADV "Butcher."
Verve coffee, Santa Cruz, Ca.
The Sermon espresso.
Farm: Joao de Campos, Bella Vista, Kebado.
Region: Alto Paranaba, La Palma, Sidamo.
Process: Dry process, Wet process.
Cultivar: Catuai, Ethiopian heirloom, Bourbon.
Elevation: 1,200-1,800 Meters.
Tasting Notes: "Fresh Blueberries, Dark Chocolate, Balanced."
Sourcing info: "This season, we present a three bean blend hailing from Central America and Africa. Jọao de Campos, a dry-processed Yellow Catuai from Brasil, offers a sturdy body and sturdy background, while Kebado, from Sidamo, provides the intense berry notes. Balancing out these extremes is Bella Vista, which is a remarkably clean wet-processed Bourbon from El Salvador that bridges the gap between the Jọao and Kebado."
Andre Thorburn L51.
Sounds interesting. What's a Greek coffee?
Not 100% sure. We were in the Greek Sponge Docks in Tarpon Springs in a bakery. The menu said "coffee" and "Greek coffee". It was made in a briki pot and had a pile at the bottom. It had an unfamiliar strong taste, but it was good. It looked like cocoa. :D
Off coffee subject....sweet blade if you don't mind me saying!!!
Andre Thorburn L51.
Greek coffee is similar to Turkish and Arabic coffee. All are very finely ground, boiled in a small pot and served in small cups.
No effort is made to filter out the grounds, so there is quite a bit of sludge at the bottom. You just sip the coffee at the top.
I have had both and it is usually very sweet.
[youtube]TleH2q86O0M[/youtube]
This how to make Arabic coffee. Be sure to follow the instructions carefully.
[youtube]Yd98i8VfKOw[/youtube]
Thanks for taking the time to post those embedded videos as I was too lazy to search for them. Not my cup of coffee but those instructions were very helpful! :D
Unboxing my new toy. Thanks to UffDa for the heads up otherwise I would be waiting until september.
How do you like your Lido2 so far? I like mine. It does a much better job than my Hario or Zassenhaus. It's not perfect. There is still a bit of a static problem and it scatters
some grounds here and there. That seems to be inherent with coffee mills.
The main problem that I am having is the weight. I have arthritis in my shoulders and the last few days have been difficult. I think that the original Lido had a square end
on the shaft and you could remove the crank and use a drill motor to drive it. It's too bad that they changed the design.
I haven't played with it yet as I am still trying to figure out how to fine tune my Pharohs and EM together. I will eventually be using the Lido for all of my other coffee toys.
The pharohs is a pain to fine tune because there isn't any guide lines to follow except the ones I make and the variables will change from bean to bean and from roast to roast so I have to change the grind, temp., flow rate, and volume frequently.
I have heard of many people complaining about the difficulty in turning the Lido 2 handle. Some people have changed out the knob for a fishing real knob and many people wish it had a longer handle. I have read light spritzing (from a spray pump bottle) your beans before grinding combined with the "WDT" (I use a paper clip to break up clumps and to evenly disperse the grinds) dispersion technique helps with the static clumps. Also I have read seasoning the grinder a lot with beans or rice will help a little.
I don't think the Lido 2 or Pharos would be a good fit for people who have injuries or dysfunctions. One might be able to shed a little weight by replacing the heavy glass container jar but I think they changed the design for the people who wanted a more stylish aesthetically pleasing grinder.
I didn't have any problems this morning. Very little pain.
Yeah, the handle on the crank is pretty stiff and doesn't seem to be getting any better. I can live with it for now. A fishing reel knob sounds like a good idea. I'm going to look into it.
I sent an email to Orphan asking about he possibility of an adapter of some sort in the future. I think one of those small electric screwdrivers would do the job. I haven't heard back yet.
I have an idea. I'll have to work on it.
One thing I found out real quick is that you can't grind while resting the thing on the rubber cup. The jar comes loose or the locking ring unlocks. I don't think it was meant to be
used like that anyway.
Yeah those lock rings sound easy to move by mistake. Some people can make a a pre-marked sticker with lines but I will probably have to use a permanent marker for the different grind positions.
Sounds like OE will take awhile to reply to your email. They recently got back from overseas and are bombarded with orders. I emailed them June 26th and still haven't received a reply about when the Lido 2 would be back in stock.
Is it possible to grind between the knees? Best of luck to you.'
Sharpies are perfect for that. I have different colors if and when I need a different grind. Right now I am only using one setting.
The lock ring came loose a couple of times and I had no problem getting back to the setting.
