I would have kept my AK-47 if it had better steel, i had to sharpen it daily, just wasn't worth it anymore so i moved on and probably wont look at cold steel again until they make a better steel AK or Recon1.
...Look, Thompson used to sandwich AUS8 between two slabs of 420 and palmed it off as San Mai II!! The whole idea behind layered steel was to use a super steel in the middle and layer the cheaper stuff on the sides to toughen it. But AUS8 isn't exactly a super steel. Now if they changed the heat treat of the inner steel and made it sharp and brittle, then layered it with tough 420, that might be one thing...but AUS8 doesn't need 420 to toughen it. Neither does VG-1...
I think it's the bread-and-butter knives (pun intended) that would benefit the most from an upgrade in steel. I've harped on this a lot at the cold steel forum. They should do what Kershaw and Spyderco do, offer the American Lawman is low- medium and high-end steel, like the Blur or the Manix. A Recon 1 or AL with 154CM would be worth an extra $40 to me. An AL in M390? What knife in that size and weightclass would be better than an AL in M390?What do most forumites think would happen if Cold Steel began using high end steels in it's folding line,like Kershaw, Spyderco etc? Do you think it would be successful? Eg, Espada XL in CPM M4 or Lawman in M390.
I think the XL espada is stupid. However a recon 1,lawman, AK in S30v would be badass. I'd probably still be carrying my Recon 1 tanto if I didn't have to sharpen it every day I used it.
