hugofeynman
- Jan 18, 2011
Can you please share where you got the info that S5 is tougher than k600? At 60hrc I'm sure that's true, but if k600 is heat treated correctly, to achieve it's optimal toughness (that heat treatment will give a Rockwell hardness of 54-56), it will be on theory tougher than s5.Well guys I came across some charts at Bohler and apparently k600 steel is slightly less tough than s5 steel, it's kind of in-between s7 and s5 but closer to s5. So that settles that. So I think of the 3 listed here 300m should be the undisputed champion of toughness seeing as it has .1% carbon less than the other too and 1.8% nickel, and a decent amount of silicon.
One other steel did catch my attention though and that was W360. Bohler claims S5 toughness with wear resistance around A2 steel.
Pretty impressive if you ask me.
I've been there searching for new ultra tough steels. At the present, although I still look from time to time for super tough steels, I care more about the maker than the steel. Having said this, if you can find Calmax at decent thickness, I would go with it. It was one of the steel choices of my all time knives guru Cliff Stamp (RIP, Master). A8mod it's also perfect for a big chopper knife, as is 8670, 15n20 and 5160.
