Jason B.
- Jun 13, 2007
I you can scratch, you can sharp, sharpen is a scratching motion!
Not always true.
Not always true.
Can you elaborate that for me, us?
You can scratch S90V with a king waterstone but it will not sharpen the steel, you could scratch it with a file too but again it would not sharpen it. Sharpening is removing metal, you need a abrasive that's harder than the steel and its carbides to do it correctly. If not you will still scratch the steel but you will not sharpen it.
Steel is not one solid mix of one material, its like a bag of fused rocks and some rocks harder than the others. A abrasive or file thats only hard enough to scratch the metal is not hard enough to cut the metal and its much harder components like the carbides. Maybe a change in the use of terms would help, instead of scratch think cut. You can scratch steel but to sharpen it would be better to cut it.
You know, as odd as that sounds, you might actually be able to use the spine of the blade to steel an edge onto a softer knife... I've never tried that, but I don't see a reason it couldn't work. Perhaps the spine of one of your Busses would be hard enough to use as a working steel.
