- Aug 1, 1999
It was and is 62HRC. By the way, mr. Hossom's knives, a lot of them are fine examples of CPM 3V used for light/medium cutting knives. Not necessarily .25" thick choppers.
I'm testing several new high toughness steels right now, but Z-Wear is not among them. In fact I'd never heard of it before I read this thread. I will observe however that their chart doesn't show it in the same league as 3V. It shows toughness about twice A2. 3V is about 7-8 times tougher than A2. Looking at the composition, while it should gain some added wear resistance from the Tungsten, it will likely not have the same fine grain as 3V and may well be more susceptible to corrosion due to the added carbon, which will increase the Chromium carbides and reduce free Chrome. The steels I'm looking at are similar to this in many respects. I don't know what the 3V patent covers, but it really is a special steel in many respects. Is it perfect? Nothing is. It tried to be when Crucible first set out to make S30V, but they sure FUBAR'd that one.
I can say this, and it may sound strange, but machinability is an important issue in these steels. I informed one company this week that I won't be using their steel on big knives because the high Tungsten level makes it just too tough to work and finish. That's why I don't work with CPM-M4. Unless the gain in practical use is significant there is simply no way to justify increading the amount of work needed to finish a knife by 100%. In user related terms that's also important. If you think sharpening some of the present high performance steels is difficult, wait 'til you try sharpening some of the Tungsten steels.
A lot of these discussions tend to become more academic than practical. Steels, and especially knife steels, are a balance of qualities that serve their intended purposes. In making knives of these steels, design and fabrication of the knife, particularly its edge geometry, are part of the steel equation that simply can't be measured in any practical sense. Is N690Co a super steel? Not by a long shot. It's a nice, clean, crucible stainless steel that when given the proper edge will serve long and well, as shown in a number of tests of the Spyderco Forester (it's no longer being made so I'm not selling anything here). What that knife had that made the steel perform well was a heavy and wide convex edge well suited to chopping while helping to protect the steel from chipping as might have occurred with a finer edge. Similarly, a few years ago I made a machete out of 154CM, which was returned a couple years later for sharpening. It had a couple small chips in the edge. I was perplexed by this because it had the same edge as the Forester and that shouldn't have happened in normal use. When I asked the machete owner how the chips happened, he told me he accidentally hit a fire hydrant with it. When I asked him how the second chip happened, he said, "I hit it twice". 154CM, a 50+ year old stainless steel.
Don't get too hung up on the nuances of steel. What matters most is how it works in the knife for doing what you need to do. Don't get pissed off if it's hard to sharpen when you asked for a steel with uber edge holding ability. Don't think poorly of stainless, then be shocked at what happens when you forget and leave your wet tool steel blade in the sheath overnight. Think about what you want the knife to do and get that knife in a steel that gives you the qualities you want for those tasks, but don't plan to slice tomatoes, cleave bone and chop hardwood logs with the same knife, regardless of the steel it uses. And above all, don't ask for a big ass chopper with 1/4" steel then complain it weighs too much to haul around or a 1/4" fighter that gets you killed because it moves too slow.
Just some thoughts.
