fudo said:Strangely enough, the S30V 110 blades are coated on the sides, but not the back.
CRH said:I have one backordered and have "heavy use" plans for it so the coating probably won't last long. Is the BOS flame logo on the blade?
819SS is 59.5HRC. I am wondering is it the same for 110? Smaller knife, may be hardness on it higher?
I don't think it is normal, but probably OK. I wouldn't send it back for this.Mongo said:I do however have a few questions... there is some lateral blade play when it is closed, is this ok/normal? There is no blade-play when opened however.
Again, not probably OK; give it a good cleaning with pressurized lubricant (like spray Rem Oil, or even WD40) and it will probably be fine. Again, wouldn't send it back.Mongo said:Also there is a "gritty" feel when opening it, again... ok/normal?
Not normal, NOT OK in my opinion. I'd send it back in a heartbeat, to either Cabelas, or straight to Buck. I'm sure it will be made right either way.Mongo said:I also noticed that there is a notch where the tip would contact the inside of the knife when closed.... ok/normal?
Mongo said:I love the coated blade, which I didn't think I would. I do however have a few questions... there is some lateral blade play when it is closed, is this ok/normal? There is no blade-play when opened however. Also there is a "gritty" feel when opening it, again... ok/normal? I also noticed that there is a notch where the tip would contact the inside of the knife when closed.... ok/normal?
All in all, I like it and will keep it and use it. This is my first Buck knife, and it just may push me into the custom 110's!
Mongo said:I'm not upset enough with any of them however to send it back.
