- Sep 29, 2008
CRK uses A2 which is basically a tool steel that will not allow "flex". The schrade was made with a lesser steel that will allow more "flex". Did you see the noss test with the kukri ? He actually had to bend the kukri in half in the vise and it still did not break. The steel was very cheap. If you did that with a high end kukri ( cold steels better models ) it would surely break as the higher end steels will not allow to much "flex". The Only High End steel I have ever seen that will allow such flex is INFINI steel Busse uses and some of the other steels their brother companies use. But in my experience, uncoated busse steel rusts, so what your achievin in one area, your givig up in another. Upon seeing the videos, that is what I came away with. A cheap steel will not hold an edge, but you can hit the edge on a file for instance and the edge will just ding or roll up, it will not chip. While a high end steel will chip because its much harder and of better quality. After the tests, I even posted for noss to use a non serrated version to prove me and others wrong, but they were never done. I still believe my reasoning is correct. This test in no way effected my buying one-piece knives. My only reasoning for wanting CRK to do a green beret and pacific in non serrated versions is that I just dont like serrations on knives as they do not help me in any way when I am using them in the field.
