Wow, thats definitely not right. I would be contacting KC and CRKT, I'm sure CRKT will want to get that knife back and figure out whats going on.Okay, so I gave this test a try again. After using some Simichrome, this is what the blade looked like before I cut the new apple:
Here is it mid-cut, with the apple culprit pictured:
And here is waiting about 7 minutes, without wiping the blade off (still apple juice on it):
And here is the blade after wiping it down:
And here is a video that hopefully shows it a little better, including the brown (oxidized) juice from the apple (it will be in 1080p once it's processed fully by YouTube):
[video=youtube;BU99x8dBGKo]https://www.youtube.com/watch?v=BU99x8dBGKo[/video]
As I say in the video, it is behaving exactly like a carbon steel knife, and is actually making the apple taste like it was cut with a carbon steel knife. This is really bizarre.
So the difference between S30V and S35Vn is the "N" and that has zero to do with "stain resistance"
After about 10 minutes of sitting on the blade, I just wiped it with a paper towel (zero water or soap)
Nothing to see....my blade smells nice and lemony though!
Did you try this?
Did you try this?
maybe OP got a faulty apple![]()
I'm about to head to the grocery store so I can get a lemon and try that too. I don't doubt that if I wiped it off with soapy water immediately it wouldn't stain. But wiping it off after about 7-10 minutes of exposure did nothing to prevent staining as it had already set in.
Now I might be getting paranoid, but it even smells like carbon steel...![]()
Repeating the quenching up to three times led to yielding new grains at the expense of others, and a coarse grained material (as rolled) is replaced by the fine grained recrystallized structure. Corrosion rate () increases for repeated quenched samples implies that corrosion rate increases as grain refinement increases. The repeated quenching refines the grains, which renders greater anodic areas than coarser grained structure and thus activates the corrosion of steel. Corrosion potential () moves to more cathodic region indicates that the corrosion process is mainly accelerated by the cathodic reactions. The corrosion resistance, calculated from EIS results, shows the same trend as those obtained from polarization measurements. Results obtained from weight loss, dc polarization, and ac impedance techniques are in reasonably good agreement.
The changes in microstructure, caused by different heat treatments, have considerable influence on the corrosion resistance of stainless steels. The heat treatment causes an alteration of carbide contained in steels. Changes in the constant B for these steels, (B = Rp · iCOR) have been observed in quenched, tempered and annealed conditions. Pitting corrosion resistance of martensitic stainless steels in quenched and tempered conditions in 0.1M H2SO4 by adding Cl− ions has been investigated.
Made in USA or China ?
I've contacted Knifecenter, I'm more than sure they will exchange it and send it back to CRKT. I've already heard from another knife collector who has one that he does not have this issue so this seems more like a problem with my specific knife. I am super curious to find out what exactly happened here though.
I hope you find out something though I have my doubts. CRKT doesn't make anything. They won't know what happened either until they here from China and I don't know what the chances of that are. Wrong blade going to the right knife? Bad batch of S30v? If that is the case we should see more of this. This is a bit of a mystery. Thanks for posting it!
Oh, have you used the knife much? Does it perform like S30v?
Unfortunately I have not, I received it on Friday along with two other knives so it has basically just been flipped and cut a few apples. At this point, I probably won't touch it until I hear back from Knifecenter.
