- Mar 31, 2016
well, there's only about 1/3 of a banner and nothing else. looks like she served her time. on the other hand, i dont need to re-profile it. just top it off. the last guy knew what he was doing
Thank you! I have read the same you say about the medium and big saws, is your information about the smallest 4' saw?Tuatahi M-tooth saws are more aggressive and harder to pull than a regular peg and raker saw.
My saw is a 4' and it's the same tooth pattern regardless of length, so if you're cutting a 1' diameter log, it's the same number of teeth moving through the kerf at any one time. You just get a longer stroke with a longer saw. When double bucking, they cut fast and laugh at hardwood. They are also heavier than a traditional saw due the the thick plate. If you buy one, keep a pair of leather gloves handy. My fingers have bled more than once using that saw.Thank you! I have read the same you say about the medium and big saws, is your information about the smallest 4' saw?
picked up a 5.5' perf lance. i'd like to run it single man, any tips?
I live in Virginia and file my saws for eastern hardwoods. Much of what I cut is dead/dry oak, so my saw teeth and rakers are set to 0.010". These settings are for the crescent or taper ground saws I run. I just filed a saw for a guy who will be cutting a mixture of tree species and I did his 0.012/0.012. Occasionally someone brings me a Jemco saw which has a heavy flat plate and I set those teeth at 0.015". A narrower set will make the saw run faster but it will get pinched sooner in top-bound wood. What are you planning to cut with it?hey trailtime, what measurements do you use for your set and rakers?
I was planning to set my rakers on the felling saws and Keystone to the .012 but being that all my saws are a flat ground blade I may set up at .014 or .015
Should I set the cutters on my plain tooth the same?
-Miller
I was talking tooth set for the flat plate saws. I do my rakers at o.o10"-0.012". If I'm filing for softwood only, I'll go deeper with the rakers, say 0.015" or so. If you're sawing non-bind wood off a timberjack or saw horse, the wider set isn't necessary. If you're cutting blowdowns with potential binds, it helps to have the teeth set a little wider. I don't file many plain-tooth saws. I think I did my last one in the 0.012-0.015 range. Always best to keep a couple wedges and a poll axe handy.
Pic link below is from a logout in Ramsey's Draft Wilderness in central VA. Most of the blowdowns were dead hemlock and a bit punky. I filed a saw just for that day with wider set and deeper rakers. Had fun with some axes too.
https://www.facebook.com/1840421083...042108337719/1446133812128536/?type=3&theater
im down here to the south of you. there's a lot more pine but mostly the same woodI live in Virginia,
I rarely cut pine, with the exception of hemlock, as it really gums up the saw. When I see a pine on the trail I start thinking "axe practice". Diesel will cut the sap but contributes to it's own mess and is one more thing to bring along.im down here to the south of you. there's a lot more pine but mostly the same wood
Looks like you have a file dedicated to jointing.
Bob
A piece of dowel wrapped with sandpaper does the job.I may need to purchase a file to get in and clean/cut the gullets.
My next chance I will see what I have in my aresenol before I go by a Nicholson made in Mexico
didnt wanna pay $27 for a repro or wait for an old one to come up so i made this out of some scrap. spaced at .012
