That's lovely trailtime. I'm no connoisseur of wood saws but I do enjoy viewing implements that are obviously sharp and have been carefully maintained.
I'm not an historian either, but here is a comparison put together from saved images:I'm not a Disston historian, but your etch is from a later saw. The "Keystone" is in script and I'd guess the cutters and rakers continue to the toe of the blade. Earlier Disstons had a run of plain teeth on the toe.
I have a photo of an 2-blade pocket knife and the metal logo on the scale is a Cross Cut Saw, done for the E.C. Atkins Saw Company. John
23.5 inch old style saw 7 TPI, fulton warranted superior. the etch is surprisingly intact for how dirty this saw was.it had enough rust to start flaking off and the handle was the standard grey dried out wood.
who ever thought it was a good idea to let me use a file before, they were insane. 4-5 teeth are still messed up but they dont effect cutting
picked up a 5.5' perf lance. i'd like to run it single man, any tips?
Tuatahi M-tooth saws are more aggressive and harder to pull than a regular peg and raker saw.Hello! I have the intention to purchase a 4' Tuatahi M tooh saw. I have read some reports in internet, but does anyone have in hand experience with this type or simmilar saws?
Once you get it started, stand close to the log and let the weight of the blade overhang the off side an far as possible. This weight will help on the pull stroke. You must saw perpendicular to the ground, no matter the angle of the log, otherwise it will fishtail on the return stroke. With two people, you can hold the saw perpendicular to the log and cut. When single bucking, it helps to put one hand on the handle and the other on the back of the saw in front of the rear handle. This will help keep the blade from buckling on the forward stroke and allow you to apply some downward pressure to the cut. Back up as you near release and cut with just the very end teeth.picked up a 5.5' perf lance. i'd like to run it single man, any tips?
I've never used a cup brush. Light rust will come off with 220g sandpaper and WD-40. Use straight back and forth strokes along the length of the blade. If rust is heavy, I put them in an electrolysis tank.one last thing, if i use a cup brush to clean and sand after, will that damage the etch?
the saw's just coated with junk and mud. im just bein lazy. it could have a fantastic etch. the teeth aren't worn down very far and there's aboslutely no pitting and only minor rustI've never used a cup brush. Light rust will come off with 220g sandpaper and WD-40. Use straight back and forth strokes along the length of the blade. If rust is heavy, I put them in an electrolysis tank.
