- Jul 3, 2004
I used to have a Recon Scout,thought it was a great knife.The day when I see a Busse with the handle broken off will be my last day of knifecollecting.
The General said:A very good friend of mine has looked at the picture of the knife breaking and pointed out that this type of failure is almost certain to happen if you allow the handle to drop below the level of the spine. This is a point I agree on. Knife failure due to user error. No question in my mind. Not a failure of the knife.
You tell 'em, Owen. I'm 110% in your camp, bud. How it could be every possible explanation except manufacturer defect (aka a lemon) is totally beyond my comprehension.OwenM said:First it was "abuse". Then it was the wrong tool for the job. Now the defective knife's failure, even after pics of more extensive use of an identical model with no problems, is "user error".
Some of you people are just plain retarded.
I think that is the lowest standard of performance I have ever seen for performance in a steel knife. I am with Owen. Raise your standards people, it is not like he was using a fillet blade, that would be user error.The General said:A very good friend of mine has looked at the picture of the knife breaking and pointed out that this type of failure is almost certain to happen if you allow the handle to drop below the level of the spine. This is a point I agree on. Knife failure due to user error. No question in my mind. Not a failure of the knife.
DaQo'tah Forge said:If I find out from him that you are right and they are the same, then I have to disagree with the maker of the Recon Scout about what steel to use on a combat knife....5160 steel is not the type of steel I would use for a combat knife,,,,,not hard enough ,,,not rust proof enough,,,For a true combat knife I would want a steel that could get very hard as I would want my knife to be about as sharp as any steel could get, and then MORE SHARP on top of that!...I would gladly give up other things in order to get a hard edge.
Combat knives on the other hand, have a 1st need to be sharp,,,,life and death sharp,,,,,this means that a combat knife is going to need a steel that can get hard.
Combat knives in history have always had to balance the same problems...getting hard, and getting broke,,,,
biogon said:I'm still waiting for the CS verdict though.![]()
Not too much chopping and prying from what I've seen/heard. Mostly light cutting and cleaning - a lot of blade get messed up scraping carbon out of M16s. Quite a few blades get destroyed by arc welding when working on electrical equipment - I like a blade with an exposed tang, so I am very, very careful about this.mwelch8404 said:Because it's 99% prying, bashing, chopping, hacking, slicing, smashing and pounding and only 1% (surely even less, in reality) gurking someone. Even leaving wetwork to specops guys, why carry a Fairbairn/Sykes that'll leave the last 1/2" in a bone. Any current or ex military see this any different? Please chime in. This is based on MY experience which may vary wildly from yours.
mwelch8404 said:I'm sure that this is based on real time military experience. Sarcasm intended.
Why in the world are soldiers carrying the same knives for combat that we sand crabs carry for "survival?" Rhetorical question.
Will P. said:DaQ - other people have explain already and in detail why you are prvoking a rude reception.
Peoria46 said:Actually, most don't (or didn't). "Survival" knives are generally a civilian affectation. Once the multi-tool is chosen, the rest is gravy and generally so much excess baggage. A good, sturdy folder has a place on the LBE, of course. Most of the knife conversations in SF centered around what made a good jumpmaster knife. Large knives (in this definition, a Kabar was about max) just weren't carried, much less jumped. Large "survival" knives were generally considered a true mark of a Leg--especially if worn upside down on the LBE. The principal selection criteria for any knife carried was its presence on a rack in the PX.
The baton should break before the knife. The only way to break a knife like that would be to use a metal baton, and I have tried that, I almost broke the bones in my hand trying to press down on the handle under the heavy impacts. Your hand isn't anywhere near the resilence of steel.Thomas Linton said:We don't know if the user was more like the Hulk ...
I am pleased to report that my RS passed with flying colors during this three day hard core expedition.
