Then Jim does it with a $5 blade 1/8" thick.
He has also done the same with thinner knives, Mora knives @ 3/32".
Noted outdoorsman Cliff Jacobson designed the IKW Cliff knife @ 1/16" L6, specifically intended to baton wood to split kindling.
This is a knife designed for pure cutting, in the Deerhunter class.
I have used these thin knives (1/16'-3/32") with a baton, no problem.
Kindling size stuff, but the limitation was blade length, not durability.
Here is a portion of a review I read earlier this week about a Chudsinki MooseSkinner, 3/32 15n20, full flat grind. Reprinted with permission of the author:
b]Part 3[/b]
Outdoors Use
The Mooseskinner serves equally as well in the outdoors as it does in the kitchen. Given its design and intended purpose, that is no surprise.
While it is a bit wide for wood carving, it is a good general camp knife.
Splitting wood into kindling to use in my Kelly Kettle proved an easy task.
Whacking across the grain to cut to lengths short enough to fit in the fire pan was very easy as well.
The fully enclosed tang makes the Mooseskinner nice to use in cold weather. It also decreases vibration. Care must be taken when using a thin knife for batoning, but a good quality knife should not be damaged in the least.
A quick flick of the spine along a ferro rod sends some nice sparks into waiting cotton tinder, ready to bring a fire to life. One thing I do with my cotton balls, is take a cotton ball, rub vasaline into it, then stick that inside a dry cotton ball. The dry cotton ball ignites easily, and the soaked one keep it burning for a good while. Once the cotton ball ignites, I add a handful of wood shavings, which the keen edge of the Moosekinner easily produces.
Comparison The Grohamnn is easier to use for hard work, it is much thicker than the Mooseskinner, so less attention and care is neeed. You can chisel through knots with no problem, with the Mooseskinner I look for clear, straight grained wood. I can also use more force with the Grohamnn when pounding
END QUOTE
Baton work is not abusive. Consider that in many cases, the edge, the weakest part of the knife, is not being stressed at all/ The wood splits ahead of the edge once you get past spine depth, you can see this especially with fairly stout, narrow, hollow ground bales like the Livesay Air Assault.
Alvin made some comments awhile ago on rec.knives about how the internet was one of the best things to happen to the knife industry from the point of view of eliminating hype.
While Alvin's argument has some validity, the free exchange of information works both ways. While there is excellent information on the web (like Jeff Clark's informative posts), it is easily dwarfed in volume by the sheer number of garbage, hype, illogical, fantasy, tacticaluberkiller slop. Some venues are obviously better in this regards than others.
So while there is actually lots of useful stuff out there, you have to have sort through a whole lot of crappolla to get to it.
