- Aug 27, 2004
It depends on how you want it. Are we talking flipping the clip to tip up carry or staying with it tip down?
Tip down or tip up is $30 plus shipping but if you do that for tip up its just threading the G10 only. For $10 more I insert metal inlayed threaded stainless inserts on the underside to screw the clip down with. G10 holds threads ok but I always recommend not making it a habit of taking the clip on and off a lot. Also, never use loctite or super glue in the holes or overtweak the screws. Using glue or loctite would cause the screw to strip the threads the first time you backed one out.
Overtweaking one does the same thing. I could always insert threaded inserts after that happened also.
Its your call there. Also please read post number one in this thread before mailing anything to me. It will explain a lot.
Thanks
STR
Thanks
STR
