How do you prefer to cut out your blade blanks? Bandsaw or grinder? I've seen a few videos with guys cutting their blanks out using a contact wheel and seems to burn through metal pretty quick. But wouldn't that ruin belts faster? I know alot of guys forge in here so I guess it doesn't apply to yall. I'm using a 4.5 in angle grinder and I hate it. Thanks
Dewalt Portaband with Swag table. I work in batches, numerous blades at a time and its the only way to go for me. I just ran a test on time and a complex blade pattern I run 13-15 blades an hour. Simpler patterns about 20 blades an hour. After years of use mine died and I had a new one that afternoon. Very useful too for all kinds of operations in knife making not just cutting out blades.
I don't have a vertical table for my portaband and I'm not sure I want one, maybe someday, but right now I usually make 3-4 of a pattern so I cut my stock into lengths, then stack them together in a vise and cut all 3-4 at the same time with the portaband. I have a Harbor Freight portaband and currently using Dewalt blades.
The tight corners I can't get I either matchstick or just cut really roughly past them and wipe that material out on a small wheel with a 36 or 60 grit belt.
Or a laser :thumbup:I haven't tried laser cutting any of the knife stock I've bought in strips since getting strips aligned on the machine is a pain.
Why do you say your not sure you want a table? Do you just clamp it in a vice?
Laser would be very convenient![]()
My opinion on the best way to cut blanks at the home shop starting with the best and most expensive:
Full size variable speed bandsaw -> 7 x 12 Horizontal / Vertical bandsaw -> portaband -> Plasma Cutter -> Torch
Knifemaking is expensive!
-Clint
I'm using an angle grinder and will probably stick with it averaging one blade a year :-D
Still in case I ever wannt to go knife maker, what is the thickest steel a portaband saw can cut?
Thank you.
