Cutting Competition
Welcome Ian. It was a pleasure to meet you at the Blade Show. I hope you and some of your other cutters can come back and visit us again.
Did you see your picture and story in the October issue of Blade Magazine?
Hi Mike, It was a real pleasure to get to the show and meet all you guys. I'm already planning on ways to make sure I get to next years event ;)
I did see the article in Blade, thank you. I wondered who that dashing looking fellow was.. NOT ! :D
I was just looking at the cutting event schedule at it looks like there are competitions in Lebanon, MO and at Blade West in Portland OR on the same day, Sept 12. Is that correct?
I hope to make it down to SMKW to see the cut in October.
Yes, Mike that is correct. We will have a group at Blade Show West and myself and several others will be at Sheperd Hills Cutlery in Lebanon.
Nothing happening in the Northeast :grumpy: Any plans for some events around these parts? I bet a show in New York City would draw some interest and be great for publicity purposes. I volunteer to help organize it :D
Nothing that I know of yet but the organization is growing everyday. I am trying to get one a little closer to me too. I am working on getting some guys together to start cutting at my place and then plan to move toward holding a points comp.
I have a quick question for Donovan, I know you said you use polished edges, what grit do you finish with? On my M4 knives (both small fixed blades at 62-63 RC) they get extremely sharp and take a very fine edge all the way out to .05 microns, and they perform extremely good. At .05 microns there ain't much in the way of teeth though, and I doubt you use an abrasive that fine.
One last question would be what is the worst edge damage you've seen on your competition knife, and how did it happen? I'd imagine practice allows you to hit very square on your cuts, where if I were chopping that 2x4 I bet I would hit it a bit off center and get some damage on that very thin edge. Lateral loading is the enemy of knife edges everywhere, especially thin ones, so is it mostly practice that allows you to get so little damage on the knives, or is the steel good enough to hold up to an off center chop?
Thanks, Mike
I would be interested in knowing more about how the cutters train and parctice. I know some have set up rope and 2x4 rigs at their homes. I know there are also surprise cuts that you really can't prepare for and I think that is a neat part of the competitions.
But what do you work on to practice? For example, is the 2x4 cut more a matter of how, or what angle, you strike the board or is is more the power of the stroke.
With the hanging rope, I notice that everyone custs it at a downward angle. I assume that it helps to keep the rope from moving away from you but it also means you are cutting through more material than you would with a horizontal cut.
The rules should require a horizontal cut for the hanging ropes just to make it more challenging IMHO.
Thanks, Mike
Very good questions, Mike.
What I meant by "still has some teeth" is I find that M4 will slice better than some steels I have used with the same sharpening sequence as below.
What I do is start with a 60 micron belt which is about the same as the 400 grit to set the initial edge, the reason I use the 60 micron is because the edges of the belt don't roll as bad. Then I go to a 30 micron belt, then 800 grit cork belt loaded with green chrome rouge, then leather strop loaded with green chrome rouge. The 8K grit diamond paste on the leather strop I used at the last comp really has my attention. Need to get some and experiment some more.
On my knives, I have wrinkled a couple. It was not bad enough that I could not get it out then resharpen. But I had a lot of help from guys who had wrecked a lot knives when I started. Now I just want to clarify that some of the other guys grind theirs thinner than I do. I leave more meat on mine because I hit harder than some guys. The wrinkles I got in mine taught me how far I could push it. When I say thinner I am referring to the primary bevel being thinner not the secondary.
I have seen others knives damaged though. In one cut we were cutting empty shotgun shells from the side. The goal was to cut off only plastic at a angle. One guy hit it too low and hit the primer pocket, it chipped the edge bad enough he was disqualified. That in my opinion is to be expected. Another guy was chopping a vertical 2X4 with a knife that had just been finished, he had not tested the knife and was a new cutter. He chipped out a pretty good section of the blade. Whether it chipped out because of user or maker I cannot say. Another cutter was using a borrowed knife that was ground thinner than he was used to. He hit the hardwood dowel at an angle and put a severe (IMHO) wrinkle in the edge. He is an experienced cutter and makes his own knives, he just decided to borrow another maker's knife to try it out. It was evident what had put the wrinkle there, it was almost the same length as the circumference of the dowel and stuck out almost 1/4" from the rest of the edge. But the steel did not crack. This is just a few examples. We push the steel hard.
One of the tests I do on a new comp knife is to chop straight down on the edge of a 2x4 as hard as I can. When chopping straight down you put more force on the edge. After I am worn out from that and have verified the edge held up with no wrinkles or chips, I then find the board with biggest, ugliest knot I can find and chop through it. If the edge survives this then I cut 2X4's in the normal manner (angle cuts) until I am satisfied that the edge is strong enough. I have also cut hardwood boards, landscaping timbers, hardwood fence posts, just whatever I can find to punish the blade until I am confident in the blade. The reason I chop as much as I can is because the more tired you become the sloppier with technique you get. So if I have cut enough to be tired then my technique is not as good as it was when I first started, therefore my wrist is rolling more and that kind of thing. Hope this answers your questions.
Yeah, I now have a full set of tables at home. I do not buy rope to practice, it is blame expensive. I mostly cut 2X4s and "recycled" stuff to practice. Yeah you are correct, for most people watching the comps, they don't know if what we are cutting is something we do at every comp or if it is the first time unless we tell them. The "surprise" cuts keep it interesting for us. You have to draw on your experience and "disect" the surprise cut the best you can. Sometimes you get it, sometimes you don't, but everytime you learn something.
The question about the 2X4 is a good one. You want to cut the 2X4 with angled cuts. You also want your left and right cuts to be far enough apart to clear the chip. This is hard to put in words. The opening you chop out in the board, we call a scarf. If you have the sides of your scarf too close together the wood that you have cut cannot chip out, therefore slowing you down. And if you hit the board with straight down chops instead of at an angle and "stair step" your scarf, then it does not chip out as easily either. The main goal when chopping 2X4s or any wood for that matter is to clear the chip. If you are clearing the chip with every chop then you are making good progress. If all that is coming off you board is sawdust then you need to widen you scarf.
That was a long answer to say that just like everything in competition, it depends. A stronger cutter can most of the time make more mistakes on a board, but the weaker competitor can overcome this strength with better technique. That was a hard question to answer. 2X4 cutting is also dependent on how well you "read" your board. If you don't look your board over good and find a knot while you are chopping then you have to adjust. This will cost you time.
This is hard to address but I am going to attempt it. In Mike Carter's post he referred to having to cut through more material when cutting on a downward angle as opposed to cutting the rope horizontally. When you hit the rope at a downward angle the end of the rope flips up and around your blade allowing the knife to continue through the rope. The bigger the rope the more angle you have to use. The less angle you use, i.e. closer to horizontal you get the more you push the rope away.
As far as the rules requiring a horizontal free-hanging rope cut it would be more challenging, no doubt. I will be frankly honest here, I have yet to cut through a free hanging rope on a true horizontal plane. Now one of the ways we have made it more challenging in the past is to hang the rope from a piece of upholstery thread and you have to cut the rope and not break the thread.
Thanks for the great answers, Donovan. You certainly answered my question and more, and I really enjoy hearing about these competitions and the practice and knives that go into making a winning combo. After seeing that video of you on the 2x4's I can see why you don't go as thin as some competitors, you generate a boatload of force on your chops, that's for sure.
Mike
Mike
I'm not the exception though, we have several other guys that hit hard too. You should really try to make it to a comp. I have had several people tell me that the videos don't do it justice.
ill be one of the cutters at blade west its a whole lot of fun
Sam fogler
dphillips....would u recommend the browning comp cutter if someone at home wanted a good representation of what a comp cutter is like....also is there anything about the knife you would change if you were to use it?....like a new handle...would u change the geometry of the blade at all....ryan
p.s.-i think i read u were somewhat familiar with it....that's why i ask
The dimensions of the Browning are correct, however, for most of us cutters it is too light. IIRC it weighs 15 oz. most comp knives in use now start at 19-20 oz. Most are also more blade heavy. I have one that I put rubber handles on. I did not thin the blade any just put a higher convex edge on it. It is a great camp knife. I know the weight difference does not sound like much but it is. I use the analogy of a baseball player preffering a bat that weighs 31oz compared to one that weighs 33 oz. It is only 2 oz, but to the user it means alot. If you added 2-3 ozs to the Browning knife biasing that weight toward the tip that would give a better representation of what a comp. knife is like.
Hope that helps.
Donavon
