- May 18, 2005
I have found that cutting green wood requires a slightly narrower 'V' to be cut than with dry or seasoned timber/lumber in many cases. With drier wood, it will tend to split along the grain nicely allowing the cutter to 'blow chips' more easily, but as Donovan says, green wood will often have a little more resistance to this type of splitting along the grain. This means that chips cannot be blown out so easily, especially if the 'V' notch is cut too wide (More length of grain between left and right cuts)
If I know I'm going to be tackling green wood of up to 4" or 5" diameter, and plenty of smaller stuff I tend to take my very old British Army Issue (Burmah Campaign) machete along rather than a working version of my competition knife. This big old beast has a blade of roughly 16" length, 3"width and is about 1/8" thick at the spine with a full flat grind and a covexed edge (edge courtesy of my own workshop) On softwoods I can normally cut straight through tree limbs of green wood up to 4" diameter in a single swipe with it so it makes light work of the task at hand.
If I'm using a large 'camp knife' similar to my competition knife I simply narrow the 'V' notch a little for green wood, and if necessary I cut in from opposing sides of the wood in a way we cannot do in cutting comps on the 2x4.
I often use my old competition cutting knife out in the field for building shooting hides and clearing undergrowth etc. It has proven to be a very useful tool for the job too
The edge on that old knife was a little too thick for competition, although not my much, but it has proven itself to be very resilient and useful in the field.
