Well... now it might actually be legal to carry in Britain.
Blades snapping like that isn't normal is it? I mean usually the reason you don't baton with a folder is because the pivot area and lock can't take the stress. The blade should not snap in the middle like that even with a bit of thumping. Looks like a manufacturing fault or what do you folks think?
Nice mod. You've nearly finished your box cutter regrind and you haven't even done any grinding yet. Sweet.
Actually, that should happen if you hit a knife with a hammer or an axe. That is exactly what happens when hardened steel is hammered on. Hardened steel is much closer to ceramic in its material properties than it is to spring steel. Being that small folders are through-hardened to RC 60 or greater, that's exactly what you can expect if you hit them with a hammer head. Now if you temper it down to the low to mid 50s, you can do a lot of beating on it without too much problem. If anything, it is proof that Spyderco is doing a proper heat treat to get high edge retention.
If you want to hammer on it, go throw the blade in the oven at 500 degrees for a long while to temper the heat treat out.
I guess that makes sense but it is unfortunate. Is this what we get for pushing for more and more edge retention?![]()
Chris "Anagarika";13529208 said:I can't believe a vertical stress can cause it fracture like it did. Sideway/lateral snap won't be surprising. Perhaps some resident metallurgy folls can analyze the smooth section.
A hatchet is softer than a knife blade, so it's not impact from same hardness steel.
