She's just too beautiful! I was about to start sharpening, but I'd hate to mess up the gorgeous finish.
So doesn't hurt to have 2! Or 3...
Gaston, you seem to be the only one who wants to talk numbers in a thread not about that topic. Plain and simple you don't buy a big Busse simply because you want a knife. You buy one because it is a multipurpose tool that can cut, chop, pry, dig, hammer, split, stab, slice, shave, drill, notch, featherstick, open cans, bust brick/concrete and about anything else you can think of while not worrying about it failing you when you need it most. If you don't comprehend that there not much more we can do for you.The NMFBM is a big 2 lb plus chopper that can do all of that, in this case it just might need a quick stropping to get it shaving sharp.
If you had ever used a Busse you would know just how quick and easy that can be.
I would love to see start your own thread to share your experiences once you chop wood with a custom hollow ground battle mistress
In the typical bigger sized offerings they are beautiful thick sharpened prybars that people can and do depend on with their lives, that's what they want because it is what they like.
Gaston444,
In my experience, too thin of an edge won't hold up to serious abuse and in my opinion is part of the Busse logic behind some of their blades. Having said that, infi with a thin blade will certainly hold up better than other steels.
Also, in my opinion, these knives aren't just made to chop wood...chop a car or whatever you want and you will have impressive results.
Bottom line is, if you thought you were going to going to come on the Busse forum and doo doo these blades and find acceptance you were incredibly wrong.
I'd buy a Busse and come back and talk smack at that time after some use. Maybe your opinion will change or maybe it won't but it's tough for it to carry much weight until that time.
This place is supposed to be fun, courteous and respectful. Thankfully I'm not a mod and have no wish to ever be one. So, the friendliest advice I can give you before you drop yet another deuce in this forum (edit: too lateI have absolutely no clue what does stropping and "shaving sharp" have to do with any kind of cutting performance... OBVIOUSLY!All I see online are 28 ounces Battle Mistresses getting their asses handed to them by 17 ounces SMIII Trailmasters, from at least two separate sources... Show me one video where the reverse happens... This tells me, from experiences with other dull knives, that even if I spent three months halving the edge geometry by hand, it would barely match the TM (which is itself completely wasting its potential with its ridiculous convex edge: Mind you, this might still be better than the V-edge if the V-edge is thicker)...
A hollow grind topped with a thin V-edge would indeed be a good thing performance-wise: I am glad we agree on that... Are you saying getting a "custom hollow ground battle mistress" is an easy fix? My professional sharpener usually won't even touch refinishing hollow grinds, and you are talking about creating one out of a single giant flat grind? That is like creating a entirely new knife out of a blank stock, not to mention the tempering issues from the grinding... That hardly sounds as "quick and easy"...
No, rather than over complicate things that way you could order one here: http://www.bussecustomshop.com
I guess people sometimes want things that simply don't work... Like convex edges and convex grinds... Yes, like asking you to follow the rules... see below
Gaston
I have absolutely no clue what does stropping and "shaving sharp" have to do with any kind of cutting performance... All I see online are 28 ounces Battle Mistresses getting their asses handed to them by 17 ounces SMIII Trailmasters, from at least two separate sources... Show me one video where the reverse happens... This tells me, from experiences with other dull knives, that even if I spent three months halving the edge geometry by hand, it would barely match the TM (which is itself completely wasting its potential with its ridiculous convex edge: Mind you, this might still be better than the V-edge if the V-edge is thicker)...
Gaston
