GeofS
“Nostra-bladus”
- Mar 9, 2018
I received notice of a package with Flitz coming from DLT. I will try polishing it. I’ll certainly update this thread.I hope the OP reports back on what they decided to do.
That is just wild to me that they just will send you an item to do the work of polishing rather than just returning and replacing the knife.I received notice of a package with Flitz coming from DLT. I will try polishing it. I’ll certainly update this thread.
Right? It almost hints at a company policy to cover for bark rivers shortcomings.....That is just wild to me that they just will send you an item to do the work of polishing rather than just returning and replacing the knife.
Thanks for the follow up. I hope it all works out in your favor.I received notice of a package with Flitz coming from DLT. I will try polishing it. I’ll certainly update this thread.
Matthew Gregory my 3V was treated by Peters' via their standard protocol for 3V, which I believe is tempered around 1000F. I can't get the cold blue to touch it. I've had to blacken it with FC.
Mike hasn’t changed in the last 20 years. That’s exactly what he did when I had a BR undergo catastrophic edge failure while doing the task for which Mike had been bragging it was ideally suited.This sort of situation has been posted about on both the Bark River Facebook pages and the DLT Insiders group after having happened to multiple knives and customers, and usually the response is Mike Stewart getting coked out of his mind and coming into the post and screaming in all caps about how MAGNACUT ISN'T TRUUUUUULY STAINLESS!!!!, and then proceeds to berate the customer as though Bark River's multiples failures on display is actually the customer's fault. Such a gem.
I had that concern myself. The way these parties have been operating, nothing is beyond the realm of possibility.Careful! Polishing it might void the warranty/return policy because you modified it.
I'm kidding. But am I really?
That’s hitting a little close to home (or garage in my case). My first knife looked way worse. My last one did too, but we’re not talking about that one.That looks like someone's "my first knife", not acceptable for a commercial product. I'd insist on returning it and not go near that company again.
Even if you were to stir boiling tomato paste with magnacut I doubt it would show signs of corrosion unless the steel had been contaminated with other steel. Spyderco uses magnacut on their Salt Series for a reason.That’s hitting a little close to home (or garage in my case). My first knife looked way worse. My last one did too, but we’re not talking about that one.
Humor aside, contamination from used tooling is possible. I’ve seen it on stainless pipe and tubing with wire wheels and sanding disks. I’d return a stainless knife that looked like that unless you were stirring boiling tomato paste or something with it.
The times I’ve seen it happen it’s pretty even. It’s not spotty. It just show wherever the contaminated sanding pad or wire wheel touched.Lost cause has a good point, if it was embedded steel would leave spots, not the full patina. Please someone if they know of a different result please share.
I mean DLT is already going to take the stance that they won't accept return on a used knife with patina.Careful! Polishing it might void the warranty/return policy because you modified it.
Even when the patina is the result of a purchase being not as described? That would be some poor customer service right there.I mean DLT is already going to take the stance that they won't accept return on a used knife with patina.
Trust me I get it, but look at DLT's return policy it is exactly as I described. I get it DLT can take the loss, or hold the manufacturer responsible. I'm just saying most retailers are not going to take return of a used knife.Even when the patina is the result of a purchase being not as described? That would be some poor customer service right there.
"My widget broke while taking it out of the box."
"Sorry, we won't accept return on a broken widget."
That’s not true if the knife is defective or mislabeled as another steel. I think even BladeHQ would accept it back after an email with pictures if the customer wanted to return it.Trust me I get it, but look at DLT's return policy it is exactly as I described. I get it DLT can take the loss, or hold the manufacturer responsible. I'm just saying most retailers are not going to take return of a used knife.
I ran a corrosion experiment a few years ago were I tested a bunch of different steels included low and high tempering. With high tempering a secondary hardening response happens that uses free chromium within the steel to form the secondary carbdies, across all steels tested this led to noticeably worse corrosion resistance.
