David Martin
Moderator
- Apr 7, 2008
Bob, Just sharpen different steels on the SiC & Inida stones ( like S30V). Giving it a legitimate try and see what results you get. Your welcome, DM
No links no spotting
I purchased from Sharpening Supplies a set of four 6" DMT stones in a wooden box for a better than superb price
Mike, That's a hard one. I have both and use them at different times. IF most of your blades contain some vanadium and you like them. Then get the SiC. It wears quicker, dishes like a waterstone. Still, you can level your stone back to flatness. I've had to do mine a few times in the last 10 yrs.. Plus, it enjoys eating S30V. My India stone is much more resistant to dishing and I've needed to level it once in 30 yrs.. The India because of it's grit structure works different/ a little slower. Still, it gives a finer edge and can do this with most steels. These stones in their combination grit form only run 19$ or less for a 2X8" and will last 2-3 lifetimes. So, not a major purchase. Giving the diamond it's due. It's a performer. Still, a Ford or Chevy will get you to the grocery store as well as a Caddy. With better economy. DM
I understand and I want something that will work now and later down the road as other steels come out.
I have the diamonds and the norton stones, diamond hones are far superior with high vanadium steels. Regardless of speculation when the vanadium increases it increases the volume of carbides which quickly makes all but diamond and CBN obsolete. You will get other abrasives to scratch the steel but it is the incorrect use of abrasives for the cutting task.
This guy explains it best.
[video=youtube;sdxf32F3j3k]https://www.youtube.com/watch?app=desktop&persist_app=1&v=sdxf32F3j3k[/video]
So if one was going to get a set of DMT diamond ones, would it be better to get the continuous or the interupted pattern for sharpening EDC blades? My folders are the PM2 cts-204p, Manix 2 XL s90v, Manix 2 s110v, Endura, Delica and Salt 1 and I have two fixed blades about 4 inches too. I have no problem spending money on a set that is MORE than I need right now cause things change, like my pocket carry and steels. I just dont want the bare minimum and then wish I got something else!
Two sets I am looking at are. (Free ship over $99)
6x2 diasharp, continuous set (xc, c, f and xf), double sided, in boxfor $78.
8x2 1/2 duosharp plus, interupted set w/1 inch continuous part (xc, c, f and xf) with the base for $139.
Comments welcome!! Thx.
P.S. I use the DMT Aligner and a Sharpmaker and have no problem except it isnt free hand! I will probably use the Aligner with the stones til I get some practice in.
I have both an 8" Duo-Sharp in C/F (mine's an older version without the continuous-surface 'pad'), and also the 6" x 2" double-sided Dia-Sharp hones in XC/C & F/EF. I LOVE all of them. The Duo-Sharp works pleasantly fast, though I don't know if it's any faster than the continuous hones (BTW, I also use DMT 'credit cards' in Fine & EF, and even they're impressively fast, at their small size). I honestly don't think one can go wrong in selecting any one of these hones.
If you go with the Duo-Sharp, I'd also recommend getting the elevated base/holder for it. Really makes using that hone easy and comfortable. You might be able to find that combo as a set; but if not, I'd get it anyway.
David
Gotta say, I agree with David here. I'm often a bit proponent of DMT stones, probably because I like to get things done quickly these days, with kids and all, I'm pretty busy. But the Nortons will work just fine, and while slightly slower, not horribly so.I realize that as I read it. To date I have not had the opportunity to sharpen S90V on a Norton India stone. However, reading back thru my posts would reveal I have sharpened S30V and S60V using a India stone. With no problems. I'm of notion the Norton stone is harder and the hardness of vanadium is over stated. It cuts vanadium on these steels... Increasing the percentage of V makes no difference. If it will cut one vanadium carbide it will cut three. Granted one could say, it's slow. But to me all these materials cut similar. The initial investment of SiC and India compared to a diamond stone is huge. Plus, the operating economy of the first two materials mentioned offer many pluses. Your ideas may vary. DM
