David Martin
Moderator
- Apr 7, 2008
Shhhhh, Ed. Don't want to rock their boat here with a different view point. Thanks, DM
At current count we have Four knowledgeable people that have posted, 'yes, you can sharpen high vanadium steels using a Norton crystalline stone.' No problem. Bob6794, I'd say this is your answer. DM
Partial answer, anyway. Curious as to the finishing grit preferred by these four (in all seriousness)? I'm betting it's not at the level where the carbides begin to interfere.
This image snip below is a hardness comparison chart from Norton's own catalog (p. 138) of their diamond & CBN 'Superabrasives' product line (link to .pdf file below). Values shown are Knoop Hardness. Note the values for Aluminum Oxide (2300), Silicon Carbide abrasive (2500), Vanadium Carbide (2700) and diamond (7000). If refining edges to a point of needing to abrade, shape or polish the vanadium carbides themselves (at 2-4µ average size), as opposed to just displacing them from the softer steel matrix (which SiC & AlOx can handle), the hardness of the carbides will be more of an obstacle. This is worth considering, and an additional part of the 'answer' in deciding if SiC or AlOx is enough, or if diamond is needed, depending on desired finish:
http://www.nortonindustrial.com/upl...talog-Superabrasives-8068-2014 Bookmarked.pdf
David
The simple objective of the chart is just to illustrate the differences in the physical properties of the base abrasives themselves. Their fundamental hardness doesn't magically change when used only on one tool or another (stones vs. wheels or belts). Point being, I'm aware it works to some extent for relatively coarse grinding (such as down to ~22µ, the grit size of Norton's EF India). But when making an initial decision about buying a tool for high-wear steels, it's useful to see these things early on, to make an informed decision about what will meet the objectives of a user, and specifically what will work better at the finer end of the finish spectrum. The OP did say he's interested in polishing these high-VC edges; diamond at <10µ and finer will do that much more effectively, with much less work (having learned this after spending too much time trying to polish & refine an S30V edge with SiC sandpaper, which never quite got it done).
Not everybody who reads these threads is going to be aware of such things; that's why it's posted.
David
I've used my DMT bench hones for 20+ years now and they still work as good as when new. That's a bargain in my book. I wore out quite a few carborundum and soft Arkansas stones before discovering diamond.
It's more related to equipment wear and tear.... When grinding using machines...... Mostly in a Production setting.......
Not about sharpening a knife blade....
One thing really doesn't have anything to do with the other....
As you've learned a lot in your sharpening (and posted a lot of good info here as well), I've also learned some things. One of which is the difference in aggressiveness and work required in using each of SiC, AlOx and diamond hones to work a particular blade. As I've mentioned (and I truly mean it), the difference between the two is significant, and I wish I'd been more aware of that from the beginning. I'm not trashing SiC or AlOx stones, and especially those from quality makers. But the lingering questions I always had about why SiC or AlOx work very well with some steels, and not quite so with others, is confirmed in knowing what the makers of such stones have been diligent enough to research thoroughly and document for the end-user. For me, it's entirely about sharpening a knife blade, and there certainly is a connection between that and the 'wear and tear' seen in industry, with sharpening or grinding tools used for high-wear steels. For a hobbyist knife sharpener, it's a sharp edge versus a somewhat dull edge for a given amount of time or effort expended. In the industrial setting, it's about how many tools/blades or other hardware they can grind efficiently before they have to replace their grinding media. Both of those things come straight down to how well a particular abrasive handles the job.
David
You can argue this subject to the end of time but facts are facts be it a grinding wheel or stone. The video I posted shows a expert in the field of abrasive grinding speaking of the interaction of abrasive and steel. It's funny there is even a argument.
If silicon carbide was all that was needed then we wouldn't have things like diamond an CBN, but thanks to Experts like the Grinding Doc we know that using the right tool for the job is very important.
Jim,
I've read your postings for quite some time and respect your time in this game and the knowledge you have. I'm a sharpening enthusiast, but my metallurgical knowledge is limited. I try to use logic and the little I know as a basis and of course listen to others that know more and see how that information combines.
I'm a little puzzled by this current back and forth over the hardness of SiC, AlO2, and Vc. I know from a previous discussion that "you have to use diamonds dude!" is a hot button issue for you, so maybe that plays into this?
Here's my question: What are you arguing? That SiC (etc) can cut Vanadium carbides despite the difference in hardness (with VC being harder)? Or that it doesn't cut it and it just doesn't matter because the results are good? That would imply that the VC is tearing out (I think). Or is there something else at work? Like the shape or ductility of the particles allows SiC to cut VC?
I'm trying to ask this from a pure knowledge standpoint. "I don't have a dog in this fight."
Thanks,
Brian.
