For fixed, as thick as I can get. I harass my favorite knifemaker to make me pieces at least 4.5 mm thick, the more the merrier. Get an Austin Goldman knife or a Faalkniven, you'll never come back from a thick yet properly executed knife.
I like the aesthetics of a thick blade, but they are mostly impractical. I have owned midtechs and customs that I sold off because they are embarrassingly bad at cutting. It's unfortunate the trend has gone that way as thin, great cutting knives with an appealing design are pretty rare now.
Anything that would ever go on a sandwich.
Really? The sharp thick knife won't cut whateve it is? What happens? The edge just slides off?
Haha, no. Of course a sharp thick knife will cut a tomato. It just won't slice it. Two reasons:
The thickness of the blade will deflect the direction of the cut. The more thickness, the more deflection; the edge wanders through the cut and the result is a wedge-shaped tomato slice.
Edible, but unattractive.
A thicker blade must displace more tomato, causing your already uneven slice to bend to accommodate passage of the blade.
The seeds and juicy innards of the tomato will remain on the cutting board and never find their way into the sandwich.
So if you want mangled, uneven sandwich components, by all means, use the thickest knife you can find.
But if you insist on carrying a thick blade, maybe consider throwing a SAK in your back pocket in case you need to make a cut with any precision.
BTW, what do you put into your sandwiches? And what knives do you consider thick? I agree that it's much easier to cut ham or sausages with a thin knife but it's not impossible to do the same with a thicker knife.
Tonight, sopressata and bucherondin on sour ficelle.
Your question made me curious, and hungry.
So I had a sandwich making contest.http://m.imgur.com/a/177hM
I compared the salami- and baguette-slicing capabilities of four knives with different thickness and geometry but all very sharp:
Mercator K55K, 2.3mm
ZT0450, 3mm
Hardware store kiridashi, 3mm
Nepalese kukri, 10mm
The results were predictable:
The thin, flat-ground K55K excelled at both tasks, and won the honor of spreading the soft cheese.
The ZT0450 did fine but not great, thanks to its narrow saber grind.
The chisel-ground kiridashi cut cleanly but at an odd angle, making it difficult to make thin slices.
The massive, steep convex of the kukri cleaved the sausage and smashed through the bread.
All of the sandwiches tasted great, though.
I admit that I'm a sucker for a thick spine myself sometimes, that kukri is about 3/8" at the handle. It's all about what you want to use it for.
Even for chopping, though, I still find myself reaching for a machete before the kukri most of the time.
Is there anything that a thin knife can cut that a thick one can't?
If we are cutting phonebook paper, tomatos, and their likes or opening mails, yes thin blades outperform thick ones. But if we are cutting tree branches, roots, wires, and similar things, thick blades are preferred. Therefore, the claim that "thin blades cut better" is actually flawed. It really depends on what is being cut.
