What device do you use to sharpen your brick?
Stitchawl
I meant brick as opposed to scraper
Not going to approach anything that you or Knifenut do obviously
Stitchawl
I meant brick as opposed to scraperI've at least gotten a knife to shave off a brick, albeit not for long (poor steel and nasty wire edge)
My money would be on the veterans who will prove knowledge/wisdom beats gadgetry.
As far as putting the correct edge on a knife for a particular use, my money would be on Richard. He's been doing it a long time.
Now it would be something if crisco came back with a video of him pushcutting wet TP.![]()
I am not saying pull through sharpeners are junk though. There are WAY too many people that satisfy their needs with them to call them junk!
This. I've defended carbide sharpeners before because they just work, and are perfectly satisfactory for most folks. My Mom, for example. She doesn't care about shaving letters off newsprint, or diamond grits, or paper wheels, or looking at the edges of her knives with a microscope. All she knows is that when her knives don't cut like they used to, she runs them through one of these carbide gizmos a few times, and the knifes are magically sharper than they were. She doesn't know how they work. She doesn't care. All she cares about is that they work. And for her, they do.
It's not about "not getting the perfect edge" or anything like that. It's about what the carbide sharpeners do to your knife: tear up the edge and bevels.
Which is exactly what happens whenever you sharpen a blade. It's likely the method knife nuts use just make it look prettier.
A carbide cutter is simply a single tooth file. If I were to take a file and use it to sharpen, say a machete, nobody here would blink an eye. But if I took a carbine cutter and did the same thing, OMG HORROR! Even if the result if functionally the same.
if you care anything about your knives, you dont use something that is going to waste steel and shorten the life of the knife. i bet anyone that uses one of thoes useless contraptions goes through a lot of knives and money.
When you do not want to do nothing, you will seek the closest thing to "nothing" you can find. A pull through sharpener is about as close as you can get...and it is hard to argue that a really horrible knife in an utterly despicable state of negligence, will perform slightly better as a result of a few passes through this thing.
