I'm not a metallurgy expert at all, but I can read charts. The elmax tempering graph in the spec sheet says the data is for a 2-time temper, holding the temp for 2hrs each time. I don't see how the act of sharpening of any manor relates to this chart. I wouldn't even begin to know how any relevant rc data could be extracted from it.
It seems to me that much of the negative discussion of elmax is anecdotal (no scientific evidence or method).
I pose the following question: Those temperatures for what thickness? You have to alter your heat treat depending on the thickness of your blade. That is why makers have started heat treating blades at stock thickness to get an even and proper heat treat response throughout the blade rather then differential (differential though still has its place dont get me wrong but needs to be done correctly as well).
Lets assume a maker has his knives water jetted, standard thickness of Elmax and then sent of for hardening.
Now from:
www.uddeholm.com: HPS_Steel_for_knives
There are a few things to consider even before hardening such as removing the stainless capsule material on the surface of Elmax. This can actually result in a lower hardness if not removed properly.
Now the maker has done all of this, heat treated his blades accordingly and now wants to start grinding since Bohler states: "This means that the final grinding can be done after hardening, eliminating heat treatment related risks such as distortion and surface decarburization" Page 7 of the linked article above.
So the next thing that has been debated for some time is "burnt edges".....really? How is it possible?
Well, lets see what Bohler has to say in their
Grinding of Tool Steel PDF
"Incorrect grinding of a hardened tool
steel can result in such a high temperature at the ground surface that
the tempering temperature of the
material is exceeded. This results in a
reduction in the hardness of the surface. If the temperature is allowed to
rise further, the hardening temperature of the material can be reached,
resulting in rehardening. This produces a mixture of non-tempered
and tempered martensite in the surface layer, together with retained
austenite, as shown in Photo 3. Very
high stresses arise in the material,
often resulting in the formation of
cracks" Page 11.
"Incorrect grinding, resulting in a
modified surface layer, often reveals
itself through burn marks—discoloration of the ground surface. In order
to avoid burning and grinding cracks,
it is necessary to keep down the
temperature of the ground part, e.g.
bymeans of good cooling, and to
employ properly dressed grinding
wheels that cut the material with
sharp cutting edges instead of simply
generating heat through friction." Page 12.
So for me it stands to reason, if there is no care taken in post hardening grinding a maker can really screw up a steel, no matter how "super" that steel might be.
