"Uddeholm Elmax is a perfectly balanced PM grade which has been designed
to reach a hardness well over 60 HRC with good corrosion resistance and excellent edge retention. The superclean production process combined with small sized powder and carbides guarantees trouble free grinding and polishing. Our process and powder properties also ensure a super fine edge and that it can be ground even at hardness up to 62 HRC. This means that the final grind- ing can be done after hardening, eliminating heat treatment related risks such as distortion and surface decarburization. It also means maximized toughness and a minimized risk for edge chipping."
So is the grinding tool steel pdf directly related to Elmax? Or just tool steels in general?
Serious question because I couldn't read the pdf other than it was from the same supplier.
Also, does the pdf relate to knife blades or plastic injection molds?
As far as I could tell it was mold specific.
Well, I read the pdf.
Since there seems to be an absence of the steel being discolored due to high heat from improper grinding, would it be more plausible to suggest that poor choice of grinding wheel and cutting parameters resulting in grinding cracks would be more likely to have caused failure?
