not until you give it a try. if it is dull then try to match the edge and get it sharp enough to use. i found out that most brand name knives have a good angle already set and will be a good for almost anything you need to cut.
i have been sharpening knives for 38 years and i have had a lot of feedback from people i sharpened knives for. i found out what kind of edge held up the best and stuck with it. i have a knife i made that i can chop down a tree and still shave hair and push cut newspaper.
for an all around edge that will hold up to every day use, a 400 grit abrasive is all the higher you need to go. going higher in grit is a waste of money and time in my opinion.
you can get a knife (that has a burr worked up on an 80 grit abrasive) shaving sharp that will also last if you finish the edge properly after removing the burr. having a knife with an edge as fine as what you would find on a razor blade is a waste since it will roll. it would be like using a straight razor to cut up a bunch of cardboard or cut anything harder than cardboard.
