Heavy handed: the gist of your post that discusses the proper edge for the application I am in agreement with. The part I took issue with was the bit about industrial cutting tools. I have been using them for more than 20 years, and there is a definite difference between the tool life on a high speed steel tool (for example a drill) depending on the surface finish of the cutting edge. I hand hone every drill I sharpen, and they outlast an as-ground edge by 3 to 1 or even better in most cases when drilling carbon steel. With industrial cutting tools, if there is a coarse ground finish, the high points tend to take all the force of the cut, which rapidly wears and rolls those high points. Once this happens, they are rubbing, not cutting. They then begin to roll and wear even more, and this worn surface becomes wider and wider, eventually wiping out the whole edge. The worn spots also build heat rapidly, which is another edge killer.
