- Jun 16, 2003
SpyderPhreak said:Wayne,
Be carefule bringing the Ritter into Canada. Many customs officials might consider an Axis lock a gravity opener.
I'm just saying that an Axis lock can be flicked open without too much trouble and without touching the Axis bar. From what I've been seeing in posts lately both here and at USN, Canadian customs seems to have been seizing an unusually large number of knives lately with the reason being given as the knives were 'Gravity Openers' (which are illegal there). Most I have read about could be flicked open with some degree of difficulty, as can just about any knife if one was to try hard enough. Even knives that were made in Canada originally have been seized for this reason.Thomas Linton said:SpyderPhreak said:Wayne,
Be carefule bringing the Ritter into Canada. Many customs officials might consider an Axis lock a gravity opener.![]()
SpyderPhreak said:I was just posting a fair warning, no need to get mad about it!![]()
PS - Here is just some proof of what I am talking about.
Well being "mad" at bureaucratic oppression is OK, just as long as you're not mad at me!Thomas Linton said:When you lose the capacity to get "mad" at bureaucratic oppression, you might as well stop breathing.SpyderPhreak said:I was just posting a fair warning, no need to get mad about it!![]()
Steven Andrews said:"Miiii-ni, cha cha cha
Miiii-ni, cha cha cha"![]()
Critter said:
Starfish said:If there's a page on the ETS web site that explains the design philosophy, that'd be cool too![]()
Critter said:Matthew,
Please see: http://www.equipped.org/rsk_mk1.htm
Bottom line is this is a very functional utility blade shape that is suitable for both fine work and rough use. It carries more strength to the tip than the relatively narrow point on the standard "modified drop point" as well as providing more belly to the cutting edge which can be very useful for soem tacks and it provides a much more functional pointed tip than the relatively blunt "modified sheepsfoot." Combine the wide-chord design with the high grind and this gives you much improved cutting geometry over either.
Hope this helps.
Doug
Critter said:Sting,
We have considered the red handle. There are two significant issues. One, the red handle has come to mean a trainer among tactical users, as you note. The obvious danger is that someone might accidentally grab the wrong knife. Two, there's the strength issue. The glass-filled Noryl GTX is extremely strong and rigid and abuse resistant. This allows for the use of the AXIS Lock "cartridge" liners instead of full liners, with obvious benefits. The down side I am told is that it doesn't accommodate the bright dyes needed to color it. On the other side of the issue, the Valox used for the brightly colored knives is not glass-reinforced. Very durable, but not nearly as rigid. This is acceptable for a trainer, but it isn't adequate for real-world use and abuse. On the Mini-Grip this isn't an issue because it has full liners (while not identical, note that the full liners of the Mini-Grip are about the size of the cartridge on the full-sized Grip). So, any lack of rigidity is made up for by those liners. Bottom line, don't expect a colored full-size RSK in the near future, sorry. As some here have noted, a bright lanyard or braided fob is one solution.
Doug
