- Mar 23, 2003
Thank you for the kind words. It really is nice to get this sort of positive feedback on this after all the time and effort and worrying we put into making it happen.
First off, if you aren't happy, neither I nor I suspect Benchmade will be happy. So, by all means, talk to Angie in Benchmade's warranty department about getting it sorted out if necessary (toll-free 1-800-800-7427 ext:150). Now, some AXIS Lock actions are smoother than others, that's simply the nature of a production process, even with Benchmade's high standards, but if anything it should improve somewhat with use, not get worse. What you describe as "gritty" doesn't sound right to me. Operation of the lock with a single finger/thumb is noticeably more difficult than using two, but it shouldn't be terribly hard for most folks. My wife cannot do it, but she has arthritis. It does seem to become easier with practice. For comparison, you may want to stop by a knife shop and try some other AXIS Lock knives to see how they feel. With regards to the rest, that all sounds pretty normal, there is some side play and enough to allow you to cock the bar slightly as described. If there wasn't then even the slightest bit of dirt could cause function problems. You don't want an extremely tight fit in the slot. What's critical is that when it locks up, then it is solid.
Hope this helps and thanks again for the positive feedback.
Doug
SpyderPhreak said:The only negative I can say is that I *may* have one with the gritty axis lock problem. :grumpy: This is the first axis I have actually owned, but I'm pretty sure it shouldn't feel like this (based on the others I've handled).
I can actually move the axis bar side-to-side in the handle (perpendicular to the scales) by about 0.030" - 0.050". Because of this play, I can also cant the axis bar slightly in the handle (so its not perpendicular when you look at it from the back of the handle). I am able to active the axis lock with just my thumb, but I have fairly large and strong hands and it doesn't slide easily. My thumb is getting sore though.When activated with two fingers, the axis bar moves freely. I didn't notice this at first, but the more and more I use (play with) the knife today, the worse it seems to be getting (that or I'm just noticing it more).
So my question to you all is this: Would you consider what I have described as one of the defective locks? Should this be sent back to BM for service?
Doug
