The thumb stud used is not the final one. You can see the final one on the design shots. Warranty is up to Jeff and Mike who has a thread here for people to weigh in on.
The knife has not been tumbled, the blade has not been beadblasted and Ti coated and the g10 scale has not been finished in a bead blast. Lots more work to do but the basic structure and movement are there.
Handle thickness (without clip): .541
Blade thickness (Max): .187
Titanium frame thickness: .140
G10 thickness: .140
Question????
What is the combined thickness of the of the Titanium and the G10.. on the G10 side???
It can't be .140" for both, that would put the handle thickness far past .541".
Just curious.
Thanks in advance??![]()
Ok, but something is not adding up on handle thickness. Handle thickness of knife is stated to be .541.42 of an inch thick not including the clip. You are packing a thick blade.
Closed end to end is is 4.39" and 4.65: with glass breaker
The .42" you reported seems to be :
.140" / 'Lock side' Titanium thickness
.140" / 'G10 side' Titanium thickness
.140" / G10 thickness
.420" / Handle thickness, '2' Ti slabs & '1' G10 slab / no blade.
.187" / Blade thickness
.607" / Add the blade and this is what we have, not including washers [which would add a few thousandths].
Where is the discrepancy???
Thanks, looking forward to this one; and thanks also for the updates.
That is what I am hoping and assuming also, that is why I was questioning the specs as they are listed.I'm assuming (and I hope I'm not wrong) that the titanium on the g-10 side will be thinner than on the lock side and that the titanium and g-10 together will add up to .140. Though the math still doesn't seem to add up.![]()
I totally with what you say about the pics, that is how it looks. :thumbup:It appears from the proto pics...
0.140" Titanium only side (with frame lock)
0.140" Titanium Fram & G-10 COMBINED Thickness
0.187" Blade thickness, +whatever the gap with washers is
So it will be 0.467"+washer gap
Not quite the same dispcrepancy as you thought. But a thickness of less than 0.5" makes sense for comforts sake.
That has been on there a while.This is the advertised warranty
From RYP web site,,,,,,,
ntroducing the ESEE DPx HEST /F
Hostile Environment Survival Tool / Folding
* pdf Download DPx-Catalog
For the first time the brutal, rugged feel and performance of the DPx HEST fixed blade has been engineered into a hard use frame lock folder. The D2 Tool Steel folder comes with a solid titanium alloy frame, Rotoblock adjustment, removable glass breaker, a U.S. made Afghan Campaign colored woven lanyard along with a unique and collectible Mr DP adjustment and multi tool. After a global search the firm of Lion Steel was selected to manufacture this knife based on their long heritage of quality and award winning solid titanium folders. The DPx HEST folder is the collaboration of Robert Young Pelton, Jeff Randall and Mike Perrin. Based on Pelton's hard time in dangerous places, ESEE's commitment to customer satisfaction and Lion Steel's mastery of manufacturing and tolerances.
The DPx HEST Folder is designed and made for hard use in hostile conditions with a lifetime warranty to registered owners.
It might be writen lifetime warranty to registered owner for now, but at no point it says unconditional or "no questions asked".
