Thanks. This is really helpful. How do you like the 3D micarta handles? I am deciding between the ghost G-10 and the 3D micarta in OD Green (either with a nimbus finish).
Wow. Very thoughtful response. I really appreciate you taking the time to lay all of that out. I should probably clarify that I'm in Houston, so I can open carry swords if I want. I should also clarify that I work in a business casual attorney's office where clients do not regularly come in person (so we are able to dress down somewhat), but I am the boss, so I'm not so worried about HR or Management coming after me as I am worried about scaring my staff.You didn't specify whether you will be in trouble if the knife is seen at work? will co workers raise a stink and report you? or will there just be questions and a bit of hassle and maybe you getting a reputation as a weirdo at work? if so as was mentioned you may want to look at deep pocket carry .
I have been carrying a FB for a few years. I have gone back and forth between pocket and belt carry. Of course outside belt carry is the most comfortable and easy access. Its also the best way to advertise you are carrying a fixed blade. You say youre in business environment so assuming no untucked T-shirts or sweaters.?
I have good results with a 5-6" FB IWB or under the belt with the handle protruding above the belt line. keeps the knife close to the body and if you untuck the front of the shirt just a bit and "fold" the shirt over the knife for the most part its concealed pretty good. unless you bring your arms above shoulder level which pulls the shirt up off the knife.
also comfort level is reduced with this method. I usually end up with chafing or rub marks on skin sometimes scratches . Its uncomfortable sitting as well.
a La griffe style knife with a curved handle reduces discomfort and is even more concealable as it hooks over the belt but those are very small specialized knives.
the Ulticlip as shown above is a great clip. I find sometimes the sheath I want to use it with isn't optimal for its use though. with pocket carry like the one shown the issue I find is when you come to re sheathing the knife. if the opening of the sheath doesn't come up to the lip of the pocket its gonna be a bit more of a hassle re-sheathing the knife . may even need to use two hands. also if the whole handle is sticking up above the pocket that's gonna get noticed right quick. Its also metal and there is the risk of brushing up against cars or doorways and causing damage . the edges are sort of sharp and its a mechanical clip with a hinge that sticks out a bit. they now have a smaller version which helps reduce the overall appearance/risk of damage
I find myself being in both situations quite regularly everyday. either I need to conceal the FB or I am in a situation where I don't worry about it being seen at all. the change in the level of concealment required could change for me 10 times a day or more. so I try to strike a balance between access/comfort and concealing the knife. and I keep the blade length below the legal limit so when/if I am questioned or stopped I will not have to worry.
right now I am doing the IWB method and am trying the Velcro strap system I stumbled across in a thread somewhere on Bladeforums. the knife is about 6" with a karambit style finger hole so I can tuck the majority of the knife down under the belt line and quickly retrieve it using the finger hole . resheathing is proving to be a bit of a PITA though with the sheath opening being below the belt line. may have to make a new sheath soon to accommodate the deeper cover.
just some thoughts to consider on your path. there are a lot of details associated with fixed blade carry that I never thought of until I started doing it. you will figure out what works best as you go . trial and error will be required.
I am deciding between a Bradford Guardian 3 and 4. This will be my first fixed blade, and I intend to use it for EDC. I tend to favor larger knives and handles (3.5-4.5 inch blades on folding knives; anything smaller than a Benchmade 940 is usually too small for me; I tend to favor the Endura over the Delica, the Crooked River over the Mini Crooked River, etc.).
However, I recognize that a fixed blade is quite large, especially in the 4-inch blade range, and it is harder to EDC for that reason. I also tend to be in more business-casual to business-business environments most of the time and have to often wear a tucked-in shirt, which would not be a problem except that I live in Houston, which tends to be too hot for jackets most of the year.
With all this in mind, I am also wondering whether I should buy a Guardian 3 or 4, and, if so, which carry options you would recommend for my situation (e.g., horizontal carry, static line, IWB with belt clip, etc.). I am open to either the kydex or leather sheath as I have minimal experience with fixed blades.
I appreciate any input provided.
This may look like an odd piece of gear, but it will work well with many factory sheaths, and as long as your slack have real pockets, they carry and draw well.
https://rcsgear.com/pocket-shield/
The ears on the upper edges catch the fabric, as you draw (like an Emerson wave), while the flat, felxible body breaks up the outline of what you're carrying, as well as keeping the item(s) indexed upright.
is that a fabric loop screwed to the sheath? so you just put the belt through the loop? Homemade?![]()
Dpx hest. 3.15 inch blade. 4 inch handle
