"How do you define "poor edge geometry?"
For me it's pretty simple, if an intended use is for chopping, it needs to be robust enough not to chip or break under heavy loads, but still cut well. If the intended use if for slicing, a heavy blade with a thick edge is wrong.
It is not that simple...
For chopping wood in the field, what I've found is, if the steel is good quality, a sabre hollow grind blade will tolerate much thinner angles while chopping, while a Full Flat Grind blade will require a thicker more open angle edge.
With a Sabre Hollow Grind, the edge angle can be as low as 12 degrees per side on a 0.020" edge base, and it will tolerate chopping all day long. (Such as a Randall Model 12)
For a Full Flat Grind knife, the edge angle will have to go up to at least 15 degrees per side, preferably sitting on a 0.030" base. Even that is borderline...
(This would not apply to a fully convexed chopper like the SM III Trailmaster or the Fallkniven Thor, because they are not true "Full Flat Grinds". I have found the SM III Trailmaster to be so thickened by the overall convexing that it performed extremely poorly: On these knives, achieving a 15 degree per side final angle is impossible or unlikely anyway, because of their overall "swelled" thickness.)
There are multiple reasons for this particular superiority of Sabre Hollow Grinds, one of the less obvious factors being that wood left on the ground, in the wild, will often "soften" on the outside and "harden" on the inside, creating a medium that will allow more aggressive lateral loads which are more concentrated on the edge itself.
This is because the softer outer will offer less support and allow more accidental twisting movements when unsticking the edge, while the harder inner core will trap the edge more forcefully in a more concentrated manner, often leading to what I call "retrieval chipping": "Retrieval chipping" often has the pattern of two slightly different chips occurring
at once close together, this delineating the outer areas of the "pinched" portion: The accidental retrieval "twisting" creates more shear force away from its center axis, hence the "double chipping" away from the center of twisting...
This typically does not happen with Sabre Hollow Grinds blades because, even with thinner edges, the faster increase of cross-section thickness (after it begins, and it of course begins later on hollow grinds than on flat grinds) either pushes the wood apart more forcefully, or naturally "unsticks" the edge better, preventing lateral loads: A hollow grind in effect "naturally" converts lateral loads into vertical "unsticking" motion...
A flat grind does not convert lateral forces into vertical motion so well, or it does it less forcefully, so the edge bending just continues without any "unsticking", which sometimes leads to
more lateral loads being involuntarily applied...
It is hard to avoid accidental "twisting" in the woods, because the level of "stability" of the wood chopped in the field can vary from thin branches moving around, to very rigid and thicker logs that have softened on the outside. In other words, the retrieval motion is not consistent, and does not have the same effects...
Now Sabre Hollow Grinds are lesser performance "choppers", in absolute terms, compared to Full Flat Grinds, but they get closer if their better protection of sharper edges (by lowering the primary grind line) is factored in: In other words, Full Flat Grinds have to be less sharp for the same durability... Sharper thinner edges mean more versatily in the tasks a chopper can accomplish, so Sabre Hollow Grinds are more versatile, all else being equal...
Another big difference is 10" Sabre Hollow Grind choppers are typically over 20-24 ounces, while Full Flat Grinds are much lighter at around 17-19. This is outweighed in my opinion by the better protection of the edge against lateral loads offered by Sabre Hollow Grinds, especially for emergency shelter building, which is very taxing on a knife...
Gaston
