I own and use both Tormek and the Edge Pro - Professional. They both have the good and bad points.
I am by no means a Tormek expert, I've only seen one other person use one. So anyone who has had hands on training from the Tormek sellers/users will probably have a lot better results than I get.
The Knife jigs for the Tormek do NOT allow for low angles on narrow width blades. Trying to sharpen a 15" long fillet knife with a max blade width of 3/4" to less than 17° using either of the Knife jigs is totally futile. (for me any width less than 1 1/4" gets done free hand). Sharpening without the use of jigs does take some practice and time to get used to and will never result in the perfect bevels many people are looking for.
Most pocket knives are much easier to sharpen on the Edge Pro than on the Tormek. Be damn careful free handing on the Tormek with a folder of any kind where the wheel rotation can close the blade. You can amputate digits or portions there of.
As has been stated the size of the leather wheel is a definite hindrance to power stropping/honing. I've owned my Tormek for over 3 years and to be honest stropping on the wheel is still a hit or miss proposition. Hands on training from a professional might help I don't know, there isn't one within 2000 miles of me. (Not that I would go more than 900 anyway.)
The Tormek will re-bevel a knife faster than you can imagine. I find it faster than a belt sander, maybe because I can exert as much pressure as I want on the Tormek where a belt sander/grinder would burn the blade. I've taken 64RC 10" chefs knife from a 23° bevel to a 12° bevel in 10 minutes on the Tormek. Change out the stone to the 4000 grit and the knife was done in another 5 minutes, 15 minutes total that includes attaching the jig, grading the stone, and the stone change.
Doing such a massive re-bevel on the Edge Pro using a twin to the original chefs knife took about 50 - 60 minutes from beginning to end. Finishing with a 3000K tape. (sorry I didn't fully time it).
The best of both world is to set the bevels (regrind) with the Tormek and then finish with the Edge Pro. I'll knock the existing bevel edges back and thin it out. Then finish with a micro bevel using the Edge Pro, using 1 stone and a series of PSA tapes. It doesn't take much time at all.
The Tormek will allow you to do a lot more tasks than just knives as well. It is not the best knife sharpener. IF you get good with the leather wheel and have several wheels for going down to 0.25 microns by power honing with various compounds I suspect one can turn out acceptable knives.
For precise even width bevels you can't beat the Edge Pro. You can do small knives, recurves and short knives on the Edge Pro that you can't easily do on the Tormek.
The 4000 grit stone is much much finer than the standard Tormek stone and is a definite nice to have. Especially if you're like me and can't seem to get the hang of the leather honing wheel. The 4000 grit stone and a standard flat 3" width leather strop allows me to almost match the Edge Pro. Almost! Say within 5-10 % points. Not without more effort however. The ultimate edge that I can get with the Edge Pro I can't obtain with the Tormek.
Final thought if you're just doing knives and the occasional pair of scissors, chisels, and plane blades then the Edge Pro - Pro is a better investment in my opinion. If you have the money by all means get them both you won't regret having both of them.
If I could only have one? It would be the Edge Pro.
