... it has been shown by others, one of the more notable being Tim Zowada, that a harder blade requires more force to break, and it takes less to permanently bend a softer one. ...
You might as well start with a blunt SV90 blade and then say how your FFD2 blade cut so much more rope.
... I see no functional reason for a knife to have a hardened edge and unhardened blade.
No, I think using a more suitable steel and stock size is a better idea.
Unhardened is just silly, you can bend unhardened even 1/4" still trivially, you might as well use mild steel...
I'm not sure if I remember. Did they only do this test 1 time? Are the results and data they got repeatable?
Gator wrote:
In my opinion, the width of the hardened portion of the FFD2 blades will be adequate for a lifetime of use.
I'll try to answer the opinions on soft back and temperlines in a separate thread. (If I can figure out how to get one started.)
Wayne
This is all a very big IF. There is no evidence that the Diamondblade people have done anything like this. They presented results where for some reason their blade had a much higher initial Ci, then cut until a fixed C was reached. Despite having the same initial sharpening treatment, they did not seem interested in understanding or explaining why the FFD2 was so much better initially. This different starting point has a big effect on the results. You might as well start with a blunt SV90 blade and then say how your FFD2 blade cut so much more rope.
In my opinion, a serious using knife should be hardened all the way through. The smith can go back and do differential tempering if he wants, but the whole blade should be hardened as a minimum.
I've never heard of unhardened spine with differential heat treat. It's been from mid 40s to low 50s as far as I've read.
Is this math?No Chuck Buck did himself directly (from memory) "We gre bored waiting for the knives to blunt on the CATRA machine, but in REAL LIFE it is otherwise." He specifically mentions the effect of forces on the edge which blunt by a mechanism other than wear. He even notes the exact cause (correctly) and makes it public. This was years ago on the forums.
Cliff, it seems like everything you want to state is math, and everything anybody else wants to state is opinion. I'm still waiting for the reference by somebody other than Cliff.This is just math, you state the judgement criteria and it isn't opinion. No more than stating that if you are looking for a steel to take shock then S7 is better than T15....there is almost always more than one way to perform a numerical calculation.
Until there are numbers attached, it's not math. I suggested that there were alternate ways to do analysis, and you ridiculed me for it, because "it's just math; it's not subjective". You still haven't shown me math -- just opinions and your assurance that it's math.This again would be math. For example you can transform a function to make it faster to calculate (less numerical operations) or more robust (less parameter correlation). These again are not opinons....you're admitting that there is a subjective component when deciding how to transform the data to derive meaning from it.
Could I have a reference, please?I showed years ago how you can make a blade progressively lose slicing aggression while maintaining a high standard of push cutting sharpness. It is strongly dependent on the carbide nature vs the abrasive.
As long as they were open in their testing and analysis methods, I'd be fine with it. But if they wouldn't give me the necessary details to replicate their testing and analysis, I'd push to get them to disclose the methods.As an aside, if someone was to perform an evaluation on your product would you want them to go forward publically with the result if they were found to not be in your favor and yet had a number of concerns such as the above which could in fact be a misleading conclusion based on less than optimal methods?
If I gave that description of the physics of any process in a paper for peer review, I'd never get it published. The only comment that I could find that had any basis in physics was "The work done on the knife equals the work done on the cut media." Everything else is stated without either proof or justification.As noted, I described the physics underlying the model in the same page as the equation is first described.
No, because I don't know which papers you consider relevant. And I'm trying to respond to your stated concerns.I don't speak german either and have only a brief working outline, as noted I am doing the survey now. I gave you a couple of key authors, did you even to a search on them and read their relevant papers?
OK, so please let me know if I understand this correctly.
1. You perform edge retention tests to determine the sharpness as a function of the amount of media cut. You do this multiple times for a given blade.
2. Using the data from step 1, you calculate the mean and standard deviation for each x-axis value.
3. With the Levenberg-Marquardt method, you use a nonlinear curve-fitting procedure to fit your model (C(x) = Ci/(1+ax^b) to the data.
4. The fitting procedure gives you values for Ci, a, and b.
5. The covariance matrix (which I believe is the same thing you called the correlation matrix) contains data on the goodness of the fit.
6. If the goodness of the fit is adequate, you have a reasonable measurement of the cutting performance. If the goodness of the fit is inadequate, you don't have a reasonable measurement, and you conclude that the data isn't yet good enough to report.
Am I close?
Thanks,
Carl
The actual measured data as I showed was perfectly fine and fitted by the model with well defined parameters. It was only when the calculations were performed on it which exploded the noise that the curve became undefined. It still fit the data fine as measured by the residuals, the noise was just so high that the curve was undefined, meaning too large of a range of parameters could satisfy the spread of the noise in in the data.Originally Posted by gator68
It doesn't look like the problem is "noise";
In my opinion, the width of the hardened portion of the FFD2 blades will be adequate for a lifetime of use. ...
The link is here
Thanks, Wayne.
HardHeart, you instigated massive thread drift. A continuation of the hard edge/soft back discussion should be continued in the thread that Cliff originally started back down aways.
This thread was started so the BYU boys and Cliff could get to some accord concerning testing methods.
Are we there yet?![]()
If you go back through all of the posts, you can find where they posted a link to an excel spreadsheet. It looks like they did the same series of tests about two times on each knife.
........ really misleading and biased statistical analysis.
Unless you are performing analysis by magic, all of what is done to data, filtering, smoothing, modeling, etc., is all calculations.
... performing analysis by magic, ....
In fact, there didn't seem to be much "science or physics" in your approach at all. Your approach is very empirical..... physics of the mechanics of blunting.
Can you please show/describe in physics or engineering principles the "physics of the mechanics of blunting". I have a hard time seeing this accounted for in the data/analysis that you have provided or directed us to on your web site.
I have to disagree here. Cliff has derived a fairly simple model for how a knife blunts. This is derived from the idea that the force applied to the material is the force applied to the knife edge; and that the force is "used" to blunt the edge and push material aside during the cut. From this simple idea, he comes up with a model -- a proposed relationship between sharpness and amount of material cut. He then tested this with data on tons of knives, and did repeated testing on the same knife. The model actually fits the data. Using the model, one can make comparisons between the performance of different knives. This is valid as long as you believe your model is useful and you take appropriate data that allows you to make meaningful fits to your parameters.Cliff,
I spent a little bit of time over the weekend trying to find and review some of your hypotheses that you have "published" on your web site, and on Blade Forums. I failed to see the
As Carl stated:
So, I'll ask again,
Why are you so afraid of peer review Cliff?
TN
