Quote:
Originally Posted by cds4byu
Is this math?
A lay person's summary. The math would be the exact responce to the data on multiple knives (CATRA result and sharpening frequencies for the users) and the lack of correlation between these and the systematic error of a blunting mechanism which is supported by published papers and also quite immediately obvious from first principles of basic physics as I outlined in the above.
Have you done the math to show the lack of correlation? If so, where can I see it?
Quote:
Until there are numbers attached, it's not math.
Obviously you do the math and calculate the determination times, correlation coefficients, etc. .
Again, have you done the math and calculated these quantities? If so, can I see it?
Quote:
If I gave that description of the physics of any process in a paper for peer review
Congradulations, you have deduced that an article written for lay people to introduce a fundamental blunting mechanism and the means to model it is not written in the same style as would be for a formal paper for a physics journal.
I've asked for a technical discussion, not a lay-person's discussion. You've claimed it's all there. I found the lay-person's discussion, but not the technical discussion. I'd still like to see the technical discussion.
You are the one actually getting PAID in this area, I am doing it as a hobby.
Actually, I'm not getting PAID anything for this work. It's just a hobby for me as well
Once references were provided in any way it should have been obvious to you that you had a responsibility to investigate it in detail.
Sorry, in my world the name of an author doesn't constitute a reference.
... Carl's summary of the modeling process was here ...
Yes, with a few points. The covariance matrix contains information on how the parameters are correlated to each other you can use this to test the goodness of fit or just look at the residuals. The model will change depending on exactly what is being plotted, sharpness or cutting ability, or blunting, but the basic principles are the same. I have shown the variants for all of them
Can you give me a list of the models you use, in addition to the one I quoted, or specific references to the other models?
There is a lot of noise in this thread and when you encourage it then it is kind of absurd to complain when serious questions are answered. If you responded in one post it is also more likely that points would not be missed.
I'm trying to avoid noise, which is why I keep trying to ask specific questions and get specific answers.
My personal preference for this kind of forum is one post per issue, which makes it easier for me to follow the specific issues. Since you apparently prefer to have the posts lumped together, I'll try to follow this procedure in the future.
As I noted AGAIN I showed the raw data, no calculations. As I noted clearly your difference equations exploded the noise they always do. This is basic math of error propogation.
I'll post a different analysis of your data later, because it would be too long to post here. Please note that it will be in a different post, which you don't like.
You might want to kind of put that as a bold disclaimer after any conclusions. "I have no idea if this result is representative of the population." (that is a math statement by the way, it has an exact definition) or in similar terms "Feel free to ignore this conclusion as it is completly unknown if the data actually supports it."
I might want to, but I don't.
LIE 1:I have shown on many occasions how the work other people have done produces valuable results.
LIE 2:I have shown on many occasions that work I have done in the past was likely influenced by systematic errors.
Since you can disprove any assertion by a single counterexample, a link or reference here would strengthen your position.
LIE 3: I have described it in great detail, showed the exact results and even put the raw data being fit on the website on many occasions.
It's not the data, it's the algorithm I've been asking about.
Of course the actual code I use to implement the algorithm isn't the issue but a straw man, you can code it in any language or even use a different algorithm if the result remain the same.
Again, it's the algorithm that's the issue. And different algorithms will almost certainly provide slightly different results.
But if you really want to see code, here is a random number generator in AWK
Cliff, you complain about noise, and then you add it. You know perfectly well that the code asked for was not random number generation code, but the code to perform your analysis. In order to minimize the noise in the thread, I won't go back to the earlier posts. Every question I've asked about your analysis method has been aimed at understanding what you do. Not one question about your method has been aimed at saying what you do is wrong. I can't make a judgment about whether I agree or disagree with your method until I understand your method, and that understanding is what I'm after.
Yeah, it was never meant to become what it has, it was started as a hobby. Had I known I was going to end up doing nonlinear modeling I would have structured it much better from the start. Right now there is a huge inertial moment preventing the organization because of the massive amount of work I know it will take.
If you're interested in help, I'd be willing to look at ways I could help you accomplish the task.
Carl
