EmersonREP
Moderator
- May 11, 2014
Well don't file anything as it will void the warranty. You can take it back to the dealer and swap it out or send it to EKI.
Thanks. The dealer says mine was hand-picked and the best of his stock.
Looks great. Out of the box, worked great. Briefly. Then started locking up.
Not just a sticky lock. The more I flipped it, the harder it was to close. I'm guessing that the liner lock moves over a tiny bit with each flip until something catches on it.
Now it sometimes takes two hands to close. And even that is difficult. I've already sacrificed part of a thumbnail.
Also starting to get blade play.
Called the dealer, great people who had handpicked this at my request. He said I got the best of the bunch and advised that Emerson's are known to be sticky.
I really wanted to love this. I am so disappointed.
Got an email today that the Spear Points are back in stock. Damn low funds !
Lock is sticky....but only if i push it open harder than it needs to open properly. Doesn't take much to open it. Detent feel is very good and strong without being in the way of a easy open.
They will break in over time but I'd rather have a sticky lock than not.
They're not all sticky from the start, but things happen. When it wears in it's no longer sticky, that's right. It's perfectly fine. I was hoping someone would pick up on the fact that I was saying I'd rather have a sticky lock then the opposite which is a lock that disengages on its own. Sorry if I wasn't clear enough.
A bit of #2 pencil lead works wonders until break in
Reporting back on my new Emerson Rangemaster Sheepdog Bowie Flipper. I have opened it using flipper, wave and thumb disc about 500 times.
Even with many reapplications of sharpie on the lock face it's still sticky when the sharpie wears off. It locks both early which is easy to unlock and in the middle which is tough. This is by far the worst I've encountered in any folder. This is easily remedied if the factory would harden the titanium lock face like Fantoni and others do.
The firce of the flipping eventually pushes the blade off center and touching the non lock liner as the pivot screw comes loose. Need to really tighten it down but eventually it loosens up again. May need to use a drop of blue loctite.
The detent is indeed weak whereby I can flick the blade out (in effect four opening methods) but it requires force. I can flick out my Viper Maga and Benchmade 761 the same way. None of them fall out due to gravity. It requires force. Not too concerned yet.
I'm keeping it to see if I can resolve the issues. For a $216 folder with fairly inexpensive 154CM & G-10 one expects more.
