What do people do thats tougher on an edge than batoning through wood that they want that kind of an edge?
Thats the way I was taught to do it and the only safe and responsible way I've ever heard it explained. Knife locks may or may not stand up to repeated sharp and heavy spine impact but they are certainly not designed for it.
Was the lock partially disengaged when you hit it?
All kinds of things, from cutting heavy wire to cutting things on hard surfaces including metal. When batoning the edge is initially wedged into the wood and so is supported from both sides, which protects it greatly from the forces and shock being applied. And of course it wasn't the edge that failed here.
Cables: Each knife will be used to push cut through CAT5 networking cable. The ZDP189 knife took 38-43 pounds of force to do this and the VG10 knife made it through twice with a 75 pound push and failed to make it through on 3 attempts using up to 100 pounds pressure. I did not feel safe using heavier pressure than this so did not attempt to finish the cuts. The performance of the VG10 knife was surprisingly poor to me initially, but 2 to 3 times less efficient than the ZDP189 profile should put it in the up to 120 pounds of force range so I suppose I shouldn't of been surprised, seeing as the ZDP189 blade seems to be outperforming the VG10 in cutting efficiency by 200-300%. Each edge was inspected for damage. Visually they were fine, running my fingernail along the edge they each felt slightly rough in the area used to cut the CAT5, but did not feel damaged significantly. Both edges looked fine under 60x magnification.
From the sound in the video it broke within the first 4 or 5 seconds of the vid. You even hesitated for a sec. when the metal snapped the second time. Further downward pressure jammed it enough to hold it together. The last upward tap released the pressure on the broken, jammed parts IMO.
*snip*Have fun and keep bashing stuff.
Understand, this isn't something I personally do (well, I've done a few tests is all) ... but I'm talking about stuff like Romex, the 14 ga. or larger copper wire used to wire homes and buildings, as well as coax, even soft steel wire. The problem mostly lies in lateral force on the edge, if an effort is made to cut straight into and through some of these things damage can be minimal, but in real world use many don't bother with being so careful.What do you define heavy wire as? I ask because previous to this test I cut CAT5 cable with this same knife and the edge was unharmed. I had planned to try coax cable later but knew that would be doing some damage. But is that something people you know typically cut? I want to know what sort of harsh materials people actually cut, because I want to continue testing my thin edges versus thick ones in the belief that my results will confirm what I've been saying for years.
Bang on knife with big stick.
Knife break.
I know you're just joking around, but just so everyone is aware for future reference....
This wasn't intentional at all, this was meant to test the edge not the lock. I've done this before and the other Endura I did this with today worked fine for it. If I ever baton something out of necessity I use a large kuhkuri, not a folder. This was not representative of what I typically use my Enduras for.
I know that others will disagree, but I do not believe that a folder like an Endura should be expected to survive that kind of abuse.
People do things with knives that surprise me. But then, who am I to judge?
