So how do you test the edge for impacts without impacting the knife.
How does an uncontrolled test, testing a function for which the knife is not designed of course, offer any real help except to say, "folders are not the best tool for batoning"? Something that most of us already realize.
Vivi- You don't test a knife edge by stressing the locking mechanism. Try cutting stuff.Cardboard and hemp or manilla rope are both reasonably abrasive and uniform, good for testing the steel on a folder's edge.
I really like what Vivi is doing in practically demonstrating that thin edge profiles are more robust then the normal knife user has imagined.
That's good. If it had been a test of batoning ability you would have failed!The test was in regards to the edge, not batoning ability.
Perhaps it would have added nothing to this particular test but at least then you would have been testing a tool within its intended usage range instead of attempting to test the edge under conditions that could be politely termed "extreme usage". Extreme usage can be fun I guess, and it is surely good entertainment for those watching, but its not a real good way to isolate a variable.An axe or more appropriate tool wouldn't of added anything to the test unless I was measuring and recording the wear resistance of whatever steel my Fiskars hatchet uses. I know that in my personal collection alone I can find 15 items more suited to the job.
I'll check it out. I do think you have the potential to be a lot better at this than many of our regular reviewers here.Also for anyone who's forgotten, I did a lot of testing with the two Endura's on how I use them in the real world, if that's what you'd rather read about. I think the article was turning out good.
I feel like I'm having to explain to a car afi why an Enzo would be a fun ride.![]()
That's good. If it had been a test of batoning ability you would have failed!How did the edge hold up?
If feeling that way makes you feel good, do your thing man and, to contiue the analogy, never mind if that car aficionado quietly listening to your explanation knows a thing or two about Ferraris and still prefers the Porsche.
I admit, it does. Thinly profiled like that, its impressive that ZDP189 held up as well as it did. How durable are you finding your reprofiled edges to be Vivi? One of the reasons I leave my knives close to factory is because I prefer to get by with cloth and leather stropping for months at a time in between sharpening jobs.Which is why I was going to do more controlled testing later. But I disagree about testing the knife past it's intended use. It passed all the real world based tests, so it was necessary to take it further to see when and how it would fail, which was one thing I was looking for. However, as things stand, I think the work done so far speaks highly of the reground edge considering it hasn't failed in any way so far.
Of course I'd adjust it. But part of buying a car is also doing proper research up front so that one can purchase a vehicle that is as close to optimal as budget and other constraints allow. That being said, I have (slightly) reprofiled every knife I've ever bought within a week or so of purchase.I guess a better analogy might be, would you buy a car and not adjust the seat once you got in? Would you leave it how the manufacturer left it, because "they know best" or "It's good enough?" Or would you adjust it to your needs and specifications so that it was optimized for you and your uses?
Vivi was comparing VG10 to ZDP-189. If there is a ZDP fixed blade, that could work. He would also need that model in VG10 to continue his work. And as far as malleable steel - that of course has no place in his testing, he was specifically testing steel and grind of a particular type. And to what end? To see how far you can go before you need a thicker edge... or a 'semi malleable steel.' As Vivi said, the edge itself hasn't failed him yet.You use a fixed blade made out of a semi malleable steel.
you've got to love spyderco![]()
great people behind the company![]()
Chris "Anagarika";6291651 said:My comment is more towards what Sal thinks might cause the lock failure (despite the abuse), whether it's the hardness, design or microfracture (pre-existing). This will lead to better design, QC, etc.
That's how one improves the quality ..
Regardless, I wouldn't of been too surprised if it broke during the batoning. It's not something I'd expect any folder to survive indefinitely. What caught me off guard was breaking the lock on an upwards handle hit.
I'm not really concerned with terminology. I have a broken knife and I'm not 100% sure why it's broken, would be cool if I could find out somehow. Not gonna say what I did to it had nothing to do with it "failing" though.
*sigh* this was supposed to be an edge durability test, not a lock test.
Gross knife abuse is a not a "test." The term "test" implies both some scientific method and some reasonable context. Abusing a knife to the point of failure involves neither.
I give Sal Glesser a LOT of credit for being patient enough even to entertain a discussion of one of his products that has been treated in this way.
I know that others will disagree, but I do not believe that a folder like an Endura should be expected to survive that kind of abuse.
So saying that the lock "failed" is IMO somewhat inaccurate. Might be better to say that you broke it.
JMO.![]()
