Fred.Rowe
- May 2, 2004
Can you get closer to the edge with the pictures?
These are with the blade sitting inside the lens can't get any closer.
All in all a good design. I can't help but notice that the current carbide scrapers using crossed plates or rods could be capable of matching variable angles by simply twisting the widget till the plates both make steady contact, and working from there. Unfortunately none of the current crop seem to realize this and don't give enough clearance to make this method work.
Looks like it should have some success in the marketplace, though the $75 proposed price tag is a might steep maybe. There are a lot of options at that price, and a lot of superficially similar units that are a lot cheaper. Whether the ERU is a better choice or not might not factor in.
Best of luck, if the amount of interest here is any indication it should do A OK.
If you can't stand the heat get out of the kitchen, one of grandma's favorite sayings. I'm used to heavy critique
Fred
So are these the before or after pictures? I am a little confused.
You and I seem to differ greatly on the definition of smooth and even ,
In the 1st picture I see an uneven bevel (smiles and frowns...# , closer to the heel we see a jaggedness that is typical of the carbide pinch type "sharpeners". Lots of scratches leftover from the initial grinding are also visible , while these aren't a sin they aren't ideal either.
Moving on to the 2nd picture this one looks more even #from what we can see#. What I don't like is the chip about 1/3 of the way in from the right hand side. Moving along the edge we see that there is some light reflecting back at us right along the very edge of the edge , #look for the white reflection at the very edge of the edge on either side of the flash spot.# I initially thought this was a burr , but I'm not certain as this type of scraper would not leave a burr. Leaving me to wonder exactly what is going on there. While I have a theory , I would be interested in seeing this knife under a Veho...
The 3rd picture is slightly more difficult to analyze , but we see some "chipping" just left of the middle , and again about 2/3 of the way down the blade #moving heel to tip# I suspect that this "chipping" is actually the tearing that these pull through carbide products are so well known for. Again on this knife we see a white reflection right at the very edge of the edge. This interests me , once again I would like to see this knife under a Veho.
Moving along to the 4th picture , initially this looks like the best of the bunch. We see scratches running both vertically #from the original grinds# and horizontally #from the ERU# , with the crosshatching near the tip you could almost play checkers there. Looks to me like the carbide blades are uneven , using the same carbide blades to do multiple angles in this type of application would cause uneven wear on the carbide. IE the bottom of the carbide will wear faster than the top. Using a tool like this to try and do an entire Scandi is a poor idea anyways , you would be much better off applying a small microbevel and leaving the main bevel well enough alone.
Given the cost of the ERU it appears to me that the results are not ideal , especially given all the superior options out there in this price range.
I think that you can afford a Veho to give us all a better look at what is actually going on at the very edge of the edge , if not I am sure someone will document it if this goes to a passaround.
Im not trying to trash you or your product , but so far I am seeing the same results I see with every other one of these. Its just a well documented fact that the ceramic ones work much better. And to be honest I'm not even a fan of those.
Kenny B
FWIW I have a veho , and am working on my microscopy skills. Its a learning curve but I am getting there. The challenge would be adequately documenting it. You use certain techniques to to pictures of the scratches a waterstone leaves , you would have to develop new different techniques to properly document the scratches this leaves behind.
Roughly 380x Magnification.
The lateral scratches are from wiping the blade off for the pictures , been carrying this knife for 3 days since sharpening.
Edited to add: I owe a big thanks to Tom Blodgett of JendeIndustries for helping me take this picture. With some advice from him I was able to drastically increase my capabilities with the scope.
Is that a true 380x or is most of that digital? Didn't think Veho went above 200x optically and the rest of the gain is blowing it up on screen. .
Fred, if you'd like a few higher mag images I could help with that.
Your definition of smooth and even is to a higher standard than the target audience of this device if those bevels are not satisfactory to you. Not that I'm saying there's a problem there, just that those sure look "good enough" to me, and I'd venture to say I know a thing or two more about keeping a knife sharp than a lot of kinfe consumers out there. Now that's not to toot my horn, what I'm saying is that being of slightly-above average discretion when it comes to edges, I would gladly call those "even and smooth", but if I was tryign to be a prefectionist about it probably not.
To me the "chip" looked more like a "dent" or a "roll" from usage, he did say it was 1084... This type of sharpener wouldn't actually remove a deformation like that. Either way there's really no indication that the sharpener caused this over just normal use so I don't think it's exactly fair to attribute it to the EDU. Saying that's the classic symptom of pull-through sharpeners ignores that the execution is not actually the same. I'm also not quite sure I follow what you're saying about uneven wear. To be honest, having worked with carbide a lot in machining, I'm not really all that convinced wear is actually an issue when we're talking about pulling knife steels through it at what are probably going to be low hardness levels, low pressure and low speed movements. I very highly doubt that any knife enthusiast will take a very hard heat-treated knife blade merely on the basis that if they actually have a knife that's heated harder than most, they are probably going to be a bit picky of their field sharpener for it. Again we have to keep sight of the target audience here...
Honestly the idea that appeals to me the most about this is the notion that you could get an edge that's a working, serviceable edge--meaning it cuts things--within a matter of seconds, and not cause damage to your edge that is commonly associated with thise pull-through carbide type of sharpeners. The key difference that's been discussed a lot here is that the faces of the carbide inserts are meant to be flush with the faces of the bevels. This is a huge difference because so many of the pull-through types I have seen and observed tend to have two things going on 1) They are very coarsely ground, with machine marks you could fild your fingernail on 2) They are cut at such angles that they actually "cut" and "attack' the steel. It makes sense too that in this type of action, the carbide on those particular syle of units will wear, because you're wearing on a fine point of the carbide. What we're seeing here is using the carbide as a flat, broad surface to actually polish and buff the edge bevel's surface, versus burnishing and shearing the edge.
In all honesty I can't say that this picture is promising though. There's a lot of "chatter" or "buffetting" marks you can see, they appear as verticle stripes going down the bevel. Then you can also see some horizontal scratches in about the midpoint of the bevel (going from edge to spine) which is evident of uneven contact. The problem is, this looks a lot like what pull-through sharpeners do to a small bevel, but on an enlarged scale. The horizontal scratches aren't so telling, because those could be from a lot of differnt things, even if they were from the device it could just mean the angle wasn't set just right.
However, the chatter marks are concerning because I think it shows that the carbide inserts while not intending to, can still produce that shearing effect on the edge. It starts to "skip" and "catch" and so it makes this little pattern, and on pull through sharpeners you can really feel it and almost hear it. My question is whether those marks are accidental (not pulling through the inserts at a good 90, perpendicular offset) or if they are a function of the intended design. In other words, say you put a small chamfer on the very edges of the carbide inserts to get ride of the hard edge. This would allow a certain margin of error for the user to not have a perfect 90 degree angle of the blade to the device, but would it still actually produce a sharpening action? If the goal here is to have the faces of the carbide themselves polish/buff/steel the edge, then having a hard edge which is still doing the "shearing" effect may be producing false-positives by still producing a good edge, but also mitigating or at least making the damage less obvious. I think it would be a real benefit for you to be able to send this device to a member who is able to produce high mangification images of the edges after use... If ANY such a person is reading this, maybe they could volunteer *hint*hint*
The price point and the target audience and everything... Well, personally I feel I'm a reallllllly cheap individual so I can't comment haha However I do think it's trying to straddle two markets maybe. I mean, the idea is that you have this convenience and quick sharpener that's simple and easy to use, and works. Problem is most people who use those already, are going to go for the cheapest possible one, and don't give a crap what damage it does to the knife--knives are virtually disposable to these types. So you can pretty much forget selling them a $75 sharpener of any variety realistically. Then there's the market of I guess "savvy" and "discerning" knife enthusiasts, but in this realm talking about "sharpness" is very principled, philosophical almost. There are no shortcuts to "true sharpness" when you find someone who really cares about how good an edge a device creates, or if it does damage to their knives, basically the more considerations a person is going to make about this, the more likely they're going to go the traditional route with stones and strops and all that great DIY stuff.
But when comparing it to stuff like the Lansky, I have to think about it in comparison to the Sharpmaker for example... I haven't used it, but from what I know the price-point is about the same. One would say, "Well, why should I buy the ERU for more than the Sharpmaker, when it aheres to the accepted philosophy "abrade the bevels until the apex meets". People will suggest that the Sharpmaker, you can just do a couple of passes on the fine hones and have your knife back to razor sharp and not damage it and so on and so forth. It's not untrue but personally I think that it still involves a little more skill than what's implied. I have a little credit-card sized hone I carry with me to do my touch ups, and it works great as described too and was $10, try to convince me the Sharpmaker is better than that.
I think having the cermaic and carbide inserts will be a huge difference over the carbide though.
The pictures of the scandi don't give a clear depiction of what is happening with the blade. Its a factory ground blade that has a heavy 100 or 120 grit grind marks running vertically the length of the blade.What is happening is the ERU is removing metal at the high spots on the bevels. Since the carbides are moving along the same plan with each pass there is a hit and miss action going on which gives the blotchy grind appearance. As I look at this blade in my lap I think it will take considerable work to remove the heavy grind marks this is not a task I would carry out wit this tool. But to show the results of using the sharpener for the task I will continue to work on it and see how it turns out.
There is much good comment and interesting points being made here on this thread, which shows me there is interest in the tool itself and the claims made.
There are not enough hours in my day where I can spend the time needed to comment and address all the queries. Please don't take offence, its that I wouldn't have enough time in the shop to produce what is needed to keep us in business.
If I can't some of the work load behind me we might get a pass around going. I have one going on BB but there is no time, at present, for me to run one here on BF.
If we can, lets discuss apples and apples and not how refined and edge can be. I make no claim other than this field sharpener will adjust to the sharpening angle of most knives with a range of 16 to 40 degrees. It is accurate and precise in settings. It does not chew up the edges of knives like most all carbide "V" sharpeners do and it possess a coolness factor that no plastic junk can claim. " I do quality work. "
I am not on this section of the forums much and am not well known here. I will say, I understand steel, its heat treatment and how to get the most out of it. I have been a full time knifemaker since 1998 and I know what sharp is and how you go about attaining that. Its like most knowledge it's such a matter of putting in the time and listening to those who know.
Thanks again for posting and your insightful comments, thats why I posted here, not to get head nods but interesting informed comment.
Regards, Fred
Some one could make them for 29.95 retail, but they wouldn't be this. They'd be a facsimile, another piece of worthless junk. Ask yourself this; whats a low end custom knife, with a quality leather sheath cost? This is a precision, hand made tool with a quality leather sheath. Which is the better value?
Thanks Lawrence; I will keep that in mind if I make that move. We are looking at the market and the investment involved; not money, you understand.![]()
