Cliff Stamp
BANNED
- Oct 5, 1998
You didn't look at the raw data, you looked at the summary. The raw data was given in the above and compared the two knives. Essentially what happened was that I sharpened the Buck and compared the work, then noted the difference in angles was likely the critical difference not the actual properties of the steel so I repeated it with different angles to illustrate.OwcA said:If raw data (presented as befits a scientific report) is not sufficient to form a meaningful interpretation...
By the way, raw data isn't enough to lead to a conclusion, usually it takes more work to turn the raw data into actual useful numbers than it takes to collect the raw data in the first place. When I started collecting data I was using a 386 to run reduction programs. I could collect the raw data in about an hour, it used to take me a week of solid computer time to take all these numbers and run predictions from them, it isn't a trivial step.
Depends, lots of measurements are hugely uncertain, it doesn't make them biased, or useless, it just makes them uncertain. You can have error bounds which are massive. For example I recently had students calculate densities of fluids using four different methods.Such a judgment is something that should be done when interpreting collected results not a measurement in itself.
The uncertainties ranged from ~5% to up to almost 90% due to limitations in measureing devices. The goal was to illustrate that science is independent of precision, you can work towards understanding of physical laws even with really crude measurements.
You can for example deduce values for the gravitational constant acceleration with a piece of string of unknown length and counting seconds in your head. I had the entire class do it and then averaged all their results showing them how all the random deviations smoothed out and they got extremely accurate and precise values, within 10% with *NO* measureing devices of any kind.
As for what I do in the reviews, usually I give bounds only on cutting and such so they are standard deviations of a number of trials. The only other times are where people asked me to estimate energy of impacts so I bounded that as well. Similar to poundages, angles and so on for flex tests.
And the fact is, that even the most precise error bounds always in the end lead to a conclusion like "It isn't likely that this correlation is random." That is the most concrete statement you can actually make, being specific about what you mean by likely which is usually <5% for most physical sciences or <1% for biology and medical research.
It has an inherently lower impact toughness shows by its chipping out.Which properties are you talking about?
-Cliff
