wetdog1911 said:JP
I don't see why not. All those activities with the same knife? Sure. But none of those sound like a life or death type of situation except shelter building where you would be putting max strain on your blade to get it done right now.
Ask Featherstone45 what he used to cut himself out of the 4x4 that went down the mountain the wrong way (Wasn't a Busse OR a Fherman) I don't think he was thinking of fuzz sticks at the time. Thank God he got out ok regardless of what he used.
Rob
Steels get more flexible not less when they are thinner.OwenM said:You take INFI down to a .02" edge, and it is no longer the super steel that people seem to think it is with that thick factory edge. It chips just like other steels.
And an AUS-6A blade did the same. This then isn't a high standard. Your blades matched the performance of low grade factory stainless.Jerry Hossom said:A 3V Espada reviewed on here some years ago cut through a shank of beef, including over 9" of flesh and more than 3" of bone without effect on the blade or splintering the outcut on the bone, even after repeated cuts.
I called yesterday and had my brother bend my Battle Mistress back and forth 270 degrees 10 times without fail. It returned to true each time.I have had a customer bend an Rc61 CPM-3v blade to 90 degree repeatedly before it finally broke on the fourth bend, twice back and forth, though not all blades will do that and I certainly don't recommend it.
So is wood.Rocks or aggregate (rock) containing concrete are not what I consider reasonable test media. Concrete in general is highly variable in its structure.
Can you really not understand its purpose. You don't cut concrete so you will know how your blade will shape concrete, you do it to examine the failure mode of the edge, the propogation of failure (main grind blowout), for accidental impacts.Lukers said:Is cutting concrete useful....no....
The Swamp Rat's are, they cut right along side the other large tacticals I have used, exceed many of them in fact. The edge geometry isn't massively thicker, in fact the edge angles are more acute than most tactical knives and Hossom's edge spec's which I have seen him quote are actually thicker.jedi_pimp said:I'm sure Eric Ferhmann could make a knife that could chop concrete like a mofojackhammer, but then it would not be much of a knife.
As long as the blade is sharp it will do this, you can do it with the GB axes. if you want to examine the edge geometry you have to use something which exerts a high binding force, like a turnip, assuming you want food as a testing media.Brian Jones said:My first test with the First Strike was to slice a tomato for a sandwich.
Both as noted. The smaller damaged can be felt by nail and was examined under mag to see if it was deformation or chips.... when you describe edge chipping, etc., are you describing a view with the naked eye or do you put it under one of the microscopes in your lab?
And when they get thinner they get weaker and more fragile too, and hence more susceptible to damage, more susceptible to both rolling and to breaking/chipping on a hard impact, or when torqued. A wire edge is thin and flexible, but it doesn't flop around when you use it hard. It breaks right off.Cliff Stamp said:Steels get more flexible not less when they are thinner.
You stated that the knives were built to your exact specifications including the heat treatment and that no cost was spared in the execution as it was all about performance but yet you have no idea on the performance? Plus there was no prototyping stage at all?Jerry Hossom said:I've not yet had a chance to test myself would perform.
Read the rest of it. A bias in the way I used it just means preconcieved expectations. For example, if a student does very well on their first 8 assignments I would expect them to do well on the next thus I have a bias about their performance. This of course doesn't mean they automatically get a good mark, just that I think it is likely. You of course grade them on what they do, not your preconceptions.Ebbtide said:So the testing is unbiased when the tester admits his bias in the first sentence?
No I just asked him. You could try it some time if you wanted to know about the R&D they do. It is not a big secret, I don't think there is a ninja death squad on me now for revealing trade secrets.Then the tester implies that he was part of the design process of the competitors brand?
What are you reading, because it isn't what I am writing. Read the reviews. This statement is competely unfounded. You should try some facts instead of just making up stuff.Whether you mean to be biased or not, it comes off that way because you always get around to the brand that you are affiliated with (that goes back to the we I quoted earlier).
No that would be useless as it contains no references to allow the performance to be judged. It is also biased as it is just showcasing the performance of one knife. There is no way to tell if performance is impressive or not if you don't say what knives also pass and what knives fail said test. This is how tests get defined meanings.A, & make no mentions of the other brands...C-Z...including brand B, that would be an unbiased review.
No, again, fracture damage is less likely when cross section decreases. The edge will get damaged more readily sure, by deformation. I have brought edges down to 8 degrees per side and hacked into knots, they will fold yes, but not chip, assuming they didn't chip before anyway.OwenM said:And when they get thinner they get weaker and more fragile too, and hence more susceptible to damage, more susceptible to both rolling and to breaking/chipping on a hard impact, or when torqued.
That is because it is overstressed steel, cold working creates preset fracture lines.A wire edge is thin and flexible, but it doesn't flop around when you use it hard. It breaks right off.
Yes as noted. The cutting ability is high. Chopping is in the same class as the GB hatchet, binds a little more, but fluid enough on most woods, except for soft pine, but that is so easy to cut it doesn't really matter as you are chewing 2"+ chunks out of it anyway.Did you do other work with the Extreme Judgment aside from the frozen log splitting before getting into the knotted wood?
You're plain wrong here, Cliff. You cannot extrapolate the results of bending an entire knife to the behavior of the steel at very thin cross sections. Edges don't behave like thicker pieces of steel. Because thin knives bend more easily than thick knives, thin edges will deform instead of chip if a thick edge from the same knife didn't chip? You will find that a LOT of us have found otherwise.Cliff Stamp said:No, again, fracture damage is less likely when cross section decreases. The edge will get damaged more readily sure, by deformation. I have brought edges down to 8 degrees per side and hacked into knots, they will fold yes, but not chip, assuming they didn't chip before anyway.
Same reason it gets easier to induce larger bends on longer blades. It isn't impressive to bend an 18" machete or sword to 90 degrees, the radius of curvature is the critical point. Wilson can induce sets in his S90V blades, then don't fracture when bent unlike 1/4" thick blades because they have greater effective ductility.
I did.Quote:
I'm reading what you wroteQuote:
Now, when you say "we" it implies that you were part of the process, doesn't it? Is that what you meant to say? I don't know, but it is what you wrote.This wasn't by chance, the knives were edge set at at a wide range and tested inbetween until the performance was reached. Then the spine was tested over a range until the required amount of flex and strength was obtained. This isn't a case of lets ask Crucible or let some heat treater decide. It is lets evaluate the cycles over a bunch of ranges and see what works best for what we want. A lot of time and a lot of broken blades later and a knife is born.
I have no Busse bias. My issue is with the fact that the overwhelming majority of your reviews come back to your favorites. Again implying that your favorites are better.Your Busse bias is strongly showing because as soon as it is mentioned that is then all that you see ignoring everything else.
I think I've been polite to you, even though I have asked some hard questions. And I do care about you as a reviewer... + or -3 cinderblocks.You see I don't really care what your opinion of me as a reviewer is, or me as a person so my credibility in your eyes is meaningless to me.
The edge specs out at just over 0.025" and is ground at 15-16 degrees per side - which is exactly as I recently specified the edge on a similar custom.
