- Mar 22, 2014
Back for more!
Sheath- the sheath is what it is, but doesn't seem to try hard at looking as awesome as one feels it should for a $200 knife. Its made of a hard polymer called zytel and has a dust finish on the outside. Don't be fooled by its cheap appearance though it definitely feels high quality in hand. The snaps and rivots are of the well made variety that don't fall apart (rare).
A sheath is a very personal piece of kit. It is impossible to make a "one size fits all" for the masses. I can't think of many stock sheathes on knives that I'm crazy about. The zytel sheath is very effective it definitely correlates to the knifes "spartan" function first theme that's hard on the eyes but works.
It may be drab but is very effective considering its water proof, does not hold or retain moisture like leather and it won't freeze your blade stuck or get too clogged with grime to retain or release the knife like kydex.
The sheath is perfect for field use with its low maintenance, lightweight and has a very slim profile. However, the trade offs are obvious. Its ugly, it can rattle when shaken, and the thin nylon webbing belt loop is lame.
I'd definitely prefer another sheath however, the zytel works and can take the same punishment from the elements as the stainless blade which is perfect for the wet weather.
Carry options are only limited by ones imagination. However,the retention strap is needed for tip up carry if attemping to get creative- the zytel retention is decent but not trustworthy upsidedown.
If Fallkniven is reading this review, I would recommend they upgrade the belt loop to something more similar to the Cold Steel S.R.K belt loop which can be taken on and off of belt without taking your belt off as well as doubling the nylon webbing for durability and rigidity. Another feature is being able to remove the belt loop entirely with hardware to attach a Tec-lok.
Another improvement would be the aesthetics. Please dump the radiator fins, they look super cheesy.
But in the end, it works, it a sheath
I want an aftermarket(apocalypse gear) sheath but don't need it.
The beauty of simplicity is making it your own.
