pjsjr
- Jan 2, 2005
That is one that has the Cerakote on the blade, right?C&C has the 891 Sniper Grey Ground Combat Knife (GCK) Spear Point...
Yes. As far as I know. Black blade.That is one that has the Cerakote on the blade, right?
Thanks, I found this out after several trials with the heat gun. Especially pressing on the scabbard using my thumbFirst, loosen the tension screws - don't let them fall out, but loosen them.
Next, WORK THE SCABBARD. That plastic scabbard will wear down as you use it.
C&C has the 891 Sniper Grey Ground Combat Knife (GCK) Spear Point for $144. I believe C&C is a supporting dealer (they are meantioned often enough). So if you missed this version the first time around (now discontinued) - this version is the 5160 steel. Not 3V steel.
I think it varies just like 110s can vary in how they open and close.I'm really surprised to see all the posts about difficulty removing from the sheath. It is hard if I just pull on it, of course. But like so many others that I consider "thumb release" sheaths, when I press down with my thumb on the kydex, directly above the tension screw, at the same time while I am pulling up on the scales - easy money, comes right out! Is mine the exception? or is this just not how most people draw from a sheath? I actually appreciate the 'thumb release' sheaths because they provide great retention and are easy to access with the thumb press technique. I understand of course those who have physical limitations, arthritis, etc. may have a totally different experience, and I wish that were not so.
I won the sharpness lottery with mine, too. I did the paper shaving test with it when I got it, and it passed, but when I saw the comments here about dull blades and mediocre sharpness, I went back and tried it on newsprint. Now I know that it's sharper than the vast majority of new knives that I purchase. It slices thru newsprint like it was butter.
I'm a very happy camper, I love mine! The hardest part for me was deciding whether to keep it pristine as a collector piece, or to beat the heck out of it camping and in the woods. For now, I'm keeping it safely stored away, because I've got several good fixed blade users already seeing work outside.
I bought 2 of the BOTM and one comes out of the sheath easily using the method you describe. The other one I find shavings of the polypropylene sheath on the G10 handle once I finally get it removed. This is after I loosened the tension screws on the sheath. I can see there is a difference in each sheath molding between the easy one and the hard one at the point where it hangs. If I swap knives, I get the same results for each sheath.
