- Dec 3, 1999
You just need to make a narrower version of what you posted in post #1 !
I imagine you are getting your bind because your clamping pressure is over the taper, not over the parallel section.
Get that clamping pressure over your surface ground, parallel ricasso, and you should be golden.
That has been the issue for sure. I probably managed to NOT say that though.
My gut feeling has been to make a different guide with that in mind, but wanted to throw the whole notion up here for some brainstorming help.
Fred- you are correct! That's something that's been floating around in my head.
So yesterday I built a new guide that is 5" long. That allowed me to put the dowel pins (bumped up to 3/8" pins) and the bolts right up close to the edge of the guide so my clamping pressure is directly over the surface ground ricasso.
I added a set of screws to offset the flex if needed, but I've clamped it down on several blades without using them and it's coming together dead nuts flat.
I'll snap a pic or two of it later and post it here.
Thanks for the ideas and conversation guys.
