Alan,
high school physics and science and length of the lever. Right?
I wish life was so simple.
In theory your "knife science" holds the water about those stop pin and pivot and lock distances. By the way, I wonder... how much difference (in Newtons) you get if you calculate the force for your Steel Will knife and some other not so perfectly engineered knife? I bet you can do the math with all your knowledge.
OK, here we have "good" Steel Will knife and this "bad" expensive knife from your example.
Now, put into equation the cross-section of the lock (how thick and wide), length of the lock and material of the lock (what steel), hardness of the lock and how the liner with the lock was made (uniformity of the structure, micro cracks in the material, sharp edges..... etc).
Now calculate or simulate how much force is needed for both those liner locks to "give up".
But this is just a tip of an iceberg.
Now you also need to add dynamic forces to the equation.... if you stab something hard there will be not just static but also dynamic forces.
Then you also need to take into account the stiffnes of the whole knife. The whole knife will deform/bend at the impact and this will also impact forces on the liner lock.
But, we are stil just scratching the surface.
Now, can your "science and physics" understand what I wrote?
