First aid for wounds
Ok, at request I have decided to do a few differant first aid write ups. This is one that is important to all outdoorsmen, and a esential part of wilderness/survival medicine. The treatment of wounds and fractures.:thumbup:
WOUND MANAGEMENT
First it is important to look at the differant types of bleeding.
Arterial- This is the least common and most dangerous type of bleeding. It involves bright red blood that comes out in large volume, and in spurts that correspond with each beat of your heart.
Venous-A cut vein typically results in a steady but relatively slow flow of dark red blood.
capillary-Capillaries are the smallest blood vessels in your body; they are about as thin as the hairs on your head.
When a minor scrape or cut opens some capillaries, the bleeding is almost always very slow and small in quantity. Your body's natural clotting mechanism is able to stop most cases of capillary bleeding within seconds to minutes.
So the first step in treating wounds is to look at what kind of wound you have, and if it is impeading breathing(will go into later) Then you must try to be as sterile as possible when preparing for treatment. Glove-up, sterilize tools etc. Also be concerned about blood-borne pathogens. You dont want to catch something by being unprepared. Remember- your safety is priority one!!!!!!!
Now we will look at treatment of differant kinds of bleeds. For every type of wound, the things you NEED to do is
1)stop bleeding
2)stop bleeding
3)stop bleeding
4) minimize infection risk
The number one way to stop bleeding in all types is direct pressure. Place dressing over wound and apply pressure, adding more dressings as they become soaked. Never remove the first ones, you will disturb the clot and be back to square one. Just apply new ones over the top of the old ones. This is not for changing bandages, just for the initial stoping of bleedng. If that doesnt work, apply pressure, and elevate extremity, If that doesnt work, apply pressure, and pinch off pressure point above site. Next, if the wound will not quit bleeding through direct pressure you need to get aggressive. This is where tournaquets and quick-clot come into play. Touniquets once fell out of favor. It is my opinion b/c they were not being used right. A tournequet is applied to essentially cut off bloodflow to extremity therefore stopping bleeding, often in the case of arterial bleeding. They need to be monitored, and loosened over time. Artirial bleeds and serious ones will need advanced medical care, in the form of clips on the vessel, Cauterization, which is the process of burning to seal it, all surgical in nature. Do not attempt this. You need lots more training then I have, and feel comfortable giving. Stick to applying a tournaquet, releasing slightly over time to avoid necrosis, and keeping the extremity with blood supply. Apply it above the wound.:thumbup:
All wounds are contanamated, and need to be treated as such.So this is where cleaning the wound is important. Us a syrynge(w/o needle) with sterile water, either bottled or boiled and cooled. Irrigate the wound washing out the contanaments., and then dress it sterilly. Mix up an iodine solution with water and clean around the site gently. Do not rub, as you do not want to dislodge a clot and be back to square one. Allow to dry for 30 seconds w/o blowing or fanning it. Apply a antibiotic ointment(externally!) and dress with sterile dressings then bandage the wound.
A dressing goes on the wound, a bandage keeps it in place.:thumbup:
After bandaging the wound, you need to check for distal pulses in the extremity, to make sure your bandage isnt too tight. Unless you have a tournaquet applied, in which case the pulses will be absent.
SUTURES
To tell if a laceration needs stitches, you will have to look at the depth of the wound. If you can see yellow sub q fatty tissue, or bone, then you will need sutures. Sutureing is the process of closing a wound by stitching it up with a needle(sterile) and suture material. The purpose is to close up the wound to aid in healing, and prevent infection. A suture knot is a square knot. If you can tie a knot, you can tie a suture knot.
here is some things I found in research to consider when stitchin up a wound.....I dont suggest doing this unless you are 100% confident.....
The completed knot must be firm, and so tied that slipping is virtually impossible. The simplest knot for the material is the most desirable.
The knot must be as small as possible to prevent an excessive amount of tissue reaction when absorbable sutures are used, or to minimize foreign body reaction to nonabsorbable sutures. Ends should be cut as short as possible.
In tying any knot, friction between strands ("sawing") must be avoided as this can weaken the integrity of the suture.
Care should be taken to avoid damage to the suture material when handling. Avoid the crushing or crimping application of surgical instruments, such as needleholders and forceps, to the strand except when grasping the free end of the suture during an instrument tie.
Excessive tension applied by the surgeon will cause breaking of the suture and may cut tissue. Practice in avoiding excessive tension leads to successful use of finer gauge materials.
Sutures used for approximation should not be tied too tightly, because this may contribute to tissue strangulation.
After the first loop is tied, it is necessary to maintain traction on one end of the strand to avoid loosening of the throw if being tied under nay tension.
Final tension of final throw should be as nearly horizontal as possible.
The surgeon should not hesitate to change stance or position in relation to the patient in order to place a knot securely and flat.
Extra ties do not add to the strength of a properly tied knot. They only contribute to its bulk. With some synthetic materials, knot security requires the standard surgical technique of flat and square ties with the additional throws if indicated by surgical circumstances and the experience of the surgeon.
Pretty advanced, and dont attempt this if you do not feel comfortable, or have had training.
As far as long term care of wounds, bandages need to be changed daily, and the wound needs to be kept clean. Monitor vital signs, skin tempature, and any changes in mental status. This will tell you if your patient is turning downhill, and infection is present. Examine the wound for swelling, redness, or discharge.
Pain controll is something else to consider.
Ok, now this is a pretty in depth subject. We could get into wound vacs, and other stuff, but I feel it will confuse more then help, for what we are trying to accomplish as far as first aid. I went a litte into sutures etc, but thats as far as I care to go into with advanced treatment of wounds.:thumbup:
Lets touch a little on sucking chest wounds and bubbling neck wounds. You dress them differantly then others They need to be sealed with an occlusive dressing. Which can be an asherman chest seal, or as simple as a credit card.
This will prevent air from entering or exiting the wound and developing a pneumothorax. Often these types of wounds are a result from gunshot wounds.
Next how about bowel eviseration. Irrigate, and dress with saline soaked dressings, and bandage with saran wrap or alluminum foil.
Shock- Look for changes in vitals, and treating for shock is never a bad idea when dealing with injury. Elevate feet above heart. Approx 25cm.:thumbup:
There is more, but this is basics.
Ok, in summary, If you can stop bleeding, and prevent infection, you are golden. Remember-----DIRECT PRESSURE FIRST, TOURNEQUET LAST.:thumbup:
FRACTURES
Fractures, they can happen easily. There are many types, open, closed, resulting from crush injury, twisting forces, bending forces etc.....Lots of times the result of Falls, or blunt force.
With closed fractures, as far as basic first aid. Stabilize the fracture check for distal pulses. If you have distal pulses splint the fracture. Secure splint above and below the site, imobilizing the joints above and below. Ater splint is applied, check for distal pulses again to make sure that your splint is not too tight.:thumbup:
A fx can present some problems. If the bone cut off a vessel when it broke, the fx will have to be set, to return bloodflow. Use manual traction to acheive this. Manual traction is achieved by gripping the extremity, and pulling untill the PT expresses relief, and pulses return. I have seen docs do about everthing but hook a pt up to a truck bumper to acheive setting a fx. It s insane to watch!!!!!!
Open fxs need to be kept sterile, and watched close for infection. Treat like a wound. Do not apply traction to an open Fx.
Ok, this is basically as deep as I think we need to go into these things. Like I said, I am not a doctor, I think this will give you at the least, an understanding and a thought process when dealing with wounds and FXs. I am just sharing my limited knowlage, and experiane with you guys. Of course there is more, and of course here may be differant ways of treating this. Thats why its called practicing.
:thumbup: great info,
About a week ago I was cutting something when my sister walked in and asked me a question, I looked away from what I was cutting to respond to her and about that time the knife had made it almost through the material and I didn't realize it so I kept cutting while talking and ended up cutting through the material and slicing into left pointer finger and skinning my thumb.
(it was a venous cut:grumpy:) I grabbed a box of band-aides and went into the bathroom to wash the cut off, but it was bleeding so badly I didn't even try some band-aides I just grabbed a hand towel and rolled in over my finger and applied pressure for half an hour until the bleeding slowed to where i could bandage it up with band-aides. Long story short, thank you for posting this thread im sure it will come in handy :thumbup:
That is great info! Something like this should be a sticky, so people can get access to this type of stuff easily. Not to mention it can be updated easily if new techniques or opinions need to be shared. I appreciate your contribution.
Alan
Thanks for taking the time to share this with us.
In the suturing section, you mention "approximation" -- what does that mean in this context?
Manual traction is achieved by gripping the extremity, and pulling untill the PT expresses relief...
OK, I have to ask about this. I've had fractures set on two occasions. In neither case would I describe the sensation as 'relief'. It hurt like a blue bastard during and for at least 5 minutes afterwards (seemed like about 30, so I figure it was 5). WTF?
Mr Williams check out Cabelas.com. Search under first aid. I was surprised not only do they carry Quikclot and another hemostatic agent, but a wound closure kit as well. Both are important items in a wilderness first aid kit.
I've been trying to find a definitive answer for this: If you lacerate yourself deep enough that you would get stitches in a hospital environment, should you risk stitching yourself up in the field, or is it safer to leave the wound open and manage it? I know people talk about sutures, butterfly closures, and superglue, but is it really advisable to close deep wounds in the field considering the non-sterile environment?
J, thanks very much for sharing. this is helpful.
one tip i read once was to practice stitching on a sliced orange...what do you think about that? obviously training is key with stitches, but do you think practice would help at all?
also curious to hear the answer to rksoon's question...
Joel, approximation is meaning - to bring the sides of the wound together.:thumbup:
I can see that, but I have also seen relief with traction to femur fractures. It has to do with the stress put on the bone and muscles when shortening of the extremity is occuring. The traction relieves some of the pressure.:thumbup:
Yes they are. I have very little experiance with quick-cot. My opinion on it is. Whatever it takes to stop the bleeding. However, use the basics first, progressing to the quick-clot. Ive heard it is great for GSWs, but so is a tampon.
Man, if you can stop the bleeding w/o stitches, and super glue is your thing- Go for it. Easier to manage sealed up with stitches, or glue, b/c its a barier for dirt etc. If you cut yourself in the backyard or in the bush, and help is a reasonable option, which most of the time it is. Id still get it evaluated in a ER and stitched. Nerve damage is easy with lacs, and you might have severed some.:thumbup:
If it were my lac. Id clean it, dress it, and get it looked at. If it was a survival situation, its whatever goes, minmizing risk of infection and stopping bleeding the priority.:thumbup:
Yep, thats good practice. If you want to make a kit, take a fish hook and grind off the bar to make a curved needle. Use fishing line and practice on an orange. Slice it, and stitch up the cut. Then when your good at it, invest in a steirle suture kit to use in emergency situations. I wouldnt stitch up every cut you get yourself, b/c nerve damage is a consideration, as well as tetnus. Seek help and treatment when its feasable.
I am not a doctor or a nurse or a paramedic.
So now that that's out of the way...
Personally I can't really see it being a good idea to stitch up a wound in the bush. Maybe I am completely wrong here, but my instinct is to keep pressure on the wound for as long as it takes to stop bleeding, and then leave it open to reduce the risk of complications due to infection.
My reasoning is this: contamination of a wound has got to be one of the more critical factors in an infection setting in. If you close up a wound with anything in it, you have got to be taking a chance. I don't know how often wounds that doctors close up get infected, but I am guessing it happens something like 1% of the time? And that is in a relatively clean environment.
So I am sure someone who is an ER doc or something can chime in here and correct me but I just have this instinctive feeling that closing a wound in the field is not a good idea.
I guess if I had the skills to stitch arteries back together or something I could see this being a good idea. But closing the edges of a wound...does this really stop the bleeding?
My feeling - and I call it a feeling because it's based on my gut and nothing else, so I am totally willing to be corrected here - is that I should be putting pressure on with a gloved hand until the bleeding slows right down or stops, and then packing the wound with gauze to keep stuff out of it, then putting some tape over top to keep the packing in, and then thinking about how to get to a doctor.
Now can someone explain why this is wrong?
Thats not wrong bro, and nobody in the medical profession will tell you otherwise. I put it in there from a survival perspective. Plane crash? Lost in the woods? That stuff when nobody is close for help. I wouldnt want to sit holding pressure for a week waiting on help.
Notice I never advocated stitching it up yourself. I said that a few times.:o
I will always give the advise to go get checked out. But if its not an option, then what? I put the knowlage I have, which is very minimal, on sutures just to touch on it for survival type things to consider. I thought it foolish to have a thread on wound management w/o touching on sutures.:thumbup:
J, thanks for sharing bro!
Have you experienced a sucking chest wound in the field ever? I would like to hear, first hand, about someone that has. I've been through quite a bit of first responder type training during my days in the AF and sucking chest wounds always came up since gun shot wounds is what we are most likely to face in my career field during the time of the training.
Is the sucking sound actually loud enough to hear and obvious enough to identify.
Great post and great thread. !!
Ive had pneumos and hemos, but never a sucking chest wound. Ive seen chest decompressions, and surgical airways, and even did a surgical airway on a deer when we were practicing, but never a sucking chest wound. My wife has though. I will ask her when she gets home from the hospital.:thumbup:
Hmm. Good discussion here guys :thumbup: I asked about the suture and wound closure because I'm paranoid about contamination and infection having seen how easily it occurs in the sterile environment of the research lab in which I work. I've seen bacteria and fungus sneak in to ruin a cell culture or an animal that has undergone survival surgery become infected even under very sterile conditions with the most careful aseptic technique. Sometimes you can only shake your fist at Murphy :D
I don't know yet if I'd suture a wound close or not; I used to and might still agree with the course of action misanthropist suggested. I'm thinking perhaps I'd only suture a wound close if leaving the wound open would hamper my mobility. If anything, maybe I'd use steri-strips/butterfly closures/improvised duct tape and cloth closures to keep a wound somewhat closed but open to drain and irrigate. Regardless, suturing or not, there is always risk of infection in a survival situation. That all being said, I still carry a suture kit and butterfly closures in my first aid kit and psk. Still on the fence with this one, but good stuff guys :thumbup::thumbup:
thanks again Jake, for putting these threads up, great for info and discussion!:thumbup:
Sweet - Thanks.
My wife works in critical care so she's learned all this stuff, but has never worked in trauma so she wouldn't have come across one as of yet.
I look forward to hearing if she's experienced one.
You can sometimes hear a gurgling/sucking sound around the wound, which can present with a red "froth" of blood. Wrap that sucker with saran wrap or other clean occlusive dressing. Not too small, or it may get "sucked" in. We used to get occlusive dressings that had a vaseline-like treatment on them. We'd throw them away and use the wrappers that they came in for sealing the wound (usually an entrance wound from a gunshot or knife).
My squad wasn't called the "South Queens Knife and Gun Club" for nothing! I digress... Back to Jake's excellent thread. I'll try to remain quiet. :)
Okay, I hear you...so suturing up a wound tends to control bleeding? Or do you have to wait for bleeding to subside?
I am just trying to get this right in my head here...it seems like unless you were looking at an arterial bleed then pressure would be enough and sutures wouldn't be necessary, but if it was arterial bleeding, wouldn't you need to repair the arteries to make it slow down?
Again I am speaking as a total novice, just my own experience with times my inside bits surprised me by being on the outside - not that I ever had to fix it myself!
Outstanding Jake! I am saving this to my favorites. I will study up. Allthough I don't have internet access when I am out hiking, I do have your cell #:D:thumbup:
