Man, you don't waste much time, do you?
Thanks m8. Love videos like this!Now that you are hand sanding, you REALLY need to check this video out. http://www.youtube.com/watch?v=u-x4wj8WC8U&feature=related
That hand sanding took my knifes from being kind of ugly as far as finish goes after I was done to actually looking pretty good, as far as the sanding goes. it is also SO MUCH MORE COMFORTABLE!!!!
Nice work.
That blade style really works well for all around stuff.
Okay, first and most obvious thing... it seems that you didn't remove the scale/decarb after HT and tempering... is that correct? If so, you have a layer of soft material on the outside of the blade that will keep it from having/holding an edge. If this is true, you should pop the scales off and finish the blade correctly in order to get a real sense for what the steel can do.
- Greg
Not bad but why not have the scales cover the whole handle?
The blade came out good but I don't get the thing with the scales not covering the metal. That seems like it would be a hot spot and form some blisters or at least discomfort after extended use.
