First Knife WIP--need some help
Looking pretty good for your first. The epoxy squeeze-out is easiest to clean up if you catch it while it is setting up, after it is no longer sticky but before it is fully hard. If you use a solvent to remove it make sure you don't get enough on the knife to contaminte the wood scales or the epoxy joint.
I use masking tape to mask off areas where I know epoxy is going to squeeze out. It can make the cleanup a bit easier but you have to get a feel for when to remove the tape or it just adds to the mess, and if you get it trapped under a scale you will always see the edge of it showing.
Excellent advice for the next one--thanks! I did plan to watch for oozing, but I had just clamped it up and a distraction arose that I needed to attend to and when I got back, it was hard--sigh!
That's one of the issues with fast-setting epoxy. On the other hand, the slow-setting types are often pretty thick and are sometimes still squeezing out an hour or more after you clamp the joint up.
On the metal parts, I am wondering if paste wax would act as a release agent, so you could easily scrape the excess epoxy off once it has dried. I keep meaning to try this but have not got around to it yet. It would not work on wood scales unless they were already stabilized/sealed, otherwise the wax would likely interfere with whatever finish you put on the scales later.
After the Easter festivities, spent the rest of the afternoon in the shop. I am going to declare this knife pretty much DONE! I've learned so much, and yes there are some issues with it and I may tweak it a bit but I think it came out pretty darned nice. Here is the final pic--I'll post more in the gallery. Thanks to all who helped with advice, opinions, materials and time!
Yup, I've been thinking about that. Need to start saving pennies for some leather working tools and materials!
You don't really need that many tools really, I think my total investment was just over $100 Canadian and that included a full shoulder. I also bought one of the Tandy Basic Leather Craft Starter kit because it was on sale at the time. I did it that way because I got some basic tooling stamps with the kit and it cost less then buying them separate.
I did pretty much the same, bought a belly piece and some snaps and setting tools, dye and waterproofing. An Xacto knife and a lot of reading and practice helped as well.
That looks really nice!
What did you do to finish off the wood? it looks very nice.
