- Feb 7, 2005
Charles May FireAnt
I've got a Scandi grind version in D2.
Just looked into Jason Wilder's order list. He has 80 DP finger neckers to make at the moment. That means he is booked for a few months.
Yeah I did notice that. The man's work is popularAnd for a reason. My opinion is you should get on the list if you can and wait in agony and anticipation
In the meantime spend some time looking at the offerings of the other makers here. There is so much good stuff.
Not knowing price point, options are limitless. Heathenknives and BlackstoneValleyKnifeworks are two makers that put out a good product and are budget minded. Jarosz Knives are superb blades but are more spendy. Those are "customs". Then you have a myriad of productions. Just whatever tickles your fancy on design
Anyone own the CS mini pendleton? Interesting knife in my opinion. Do let us know if you've used it!
Good steel, good geometry, a little skeptical about the loose handle that may let water in and let it rust the knife inside the handle that isnt removable.
Kanetsune makes a cool little knife with a bamboo handle... I forget what it is called exactley but I WANT ONE!
Yes, kind of.
Personally I am a big fan of small fixed blades. I have modified some to my taste, as you can see from the picture above. The handle is made of cord soaked in epoxy. It fits the original sheath well.
One of my favourites is Enzo necker. Quite affordable, but might not be available overseas. Quality is excellent.
What I carry now is a small puukko that I modified, did a major reshaping of the handle. Also discarded the original sheath, used just the plastic liner and made a pocket sheath.
DUDE. Seems like we share the same taste. I just found a site with the same enzo you have. is 60$ a good price? it's the first time i've seen it but i'm in love...great work on the CS pendleton. Was it a tough time modifying the handles? How are the two knives overall? (CS and enzo)
The price of the Enzo sounds quite reasonable. The handle of the CS was easy to remove with sharp knife, the lanyard tube holds it in place and came off with a hacksaw. Wrapping the handle with cord was quite easy too, I used two color boot lace. I clamped the knife to workbench, mixed some slow epoxy and dabbed it on the cord while wrapping, holding cord tight with one hand. I also used a hot air blower to make the epoxy more liguid, that way it got well in the cord. After drying it took just some sanding to finish, the handle is now like hardwood and gives a good non-slip grip.
Both knives are in my opinion well worth the price. Like I said, Enzo is my favourite though. A good all-round knife. Only thing I did (that does not show in the picture) was that I sanded the handle corners more round, then oiled with teak oil. Now it is just perfect. The CS, on the other hand, is a very slim knife and therefore easy to carry so consider your carrying method. Enzo's leather sheath is suitable for both belt and pocket carry, but the knife + sheath combination is bulkier than CS.
